C5 Windshield Wiper reset problem . . .
1st Gear
HI - I am not a novice owner, having owned seven Corvettes dating back to 1967, however, I have NEVER encountered this problem before. Any suggestions, help, or assistance will be greatly appreciated. Approximately a month ago the windshield wipers on my 2003 50th Anniversary coupe failed to return the normal "off" position. All of the other wiper functions are normal, but they stop at an almost horizontal position when turned off(?). I have disconnected the positive battery terminal and let the vehicle sit for an hour, but that made no difference. Has anyone encountered this and, if so, were you able to affect a fix, short of taking the car to a Chevrolet dealer, given the exhorbitant hourly labor rates? As I said, any and all help, suggestions, and/or assistance will be greatly appreciated. Thanks, in advance, for your time and assistance. - COL Steve Ritz, USA (Ret)
(Hopefully, I have attached two files (photos) of what I am talking about)
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
[color=#4e5f70][b]HI - I am not a novice owner, having owned seven Corvettes dating back to 1967, however, I have NEVER encountered this problem before. Any suggestions, help, or assistance will be greatly appreciated. Approximately a month ago the windshield wipers on my 2003 50th Anniversary coupe failed to return the normal "off" position.
There is a good video on youtube (I wish I could link to it from work) that shows replacement of the wiper motor. He goes in to detail about resetting the wiper position. It's not hard to do, but there is a procedure.
My guess is your washer motor got wet and is now toast. Udders clear? I would consider a new one (50 bucks) from most all the retail outlets. Getting the wipers off is the hardest part of the job. You can d it!
Doug1 (04-26-2023)
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
Doug1 (04-26-2023)
Received 1,261 Likes
try pulling the fuse in the passenger floor board, reinsert the fuse, and see if it goes back to the normal position
Mine would turn themselves on while cruising around. I tried cleaning out the area of the circuit board after finding that the udders were completely clogged and had water in the box. I ended up having to replace the wiper motor. Calibration can be interesting if you don’t get the stop arm in the correct spot.
Doug1 (04-26-2023)
Start with recalibrate the wipers.
There is a bump tab on top of the motor that controls the park position.
If it gets out of whack, the wipers park in the wrong spot.
If it works, (and it should for a while), then you're golden.
Otherwise, the dealer will likely tell you you have to replace the wiper motor.
IIRC, its 300+ for that job.
Doug1 (04-26-2023)
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Greetings fellow C5 lovers!
I know this is a 4-year old thread.. but there are few good posts on how to solve this problem.
The video above is good to show how to access and remove the wiper motor.. but it's not necessary to fix this problem.
Pulling fuses won't do it either - it's a mechanical problem.
My wipers ran normally - all speeds -- until you turned them off.. They would "park" in the middle of the window.
My video below shows the proper operation of the park mechanism (after I fixed it). The little metal tab should touch the bar on each revolution. You can hear it click in the video. Then, when the motor reverses, the tab catches on the bar, and the wipers park. The tab is spring loaded so it sticks out. Mine was caked with gunk and would not spring out, causing the wipers to park in the middle of the windshield. I just cleaned it and lubed it - Easy fix - good luck!
Fred
Fred
The following 3 users liked this post by SDVette:
Having a different wiper problem on my 2002 with 195,000 miles:
Mostly just don't work, once in a while a stroke or two then quit.
Fuse OK, replace anyway no help..
No unusual noises.
I figure its time for a new motor. Any other suggestions?
No unusual noises.
'23-'24
In messing with my wipers some more, I think it is the steering column stalk switch based on the following:
It has started out intermittent, which could be the switch, motor, or wiring.
Then it didn't work at all
Then it worked, but wouldn't turn off until ignition was off, which to me says switch
Hasn't been to my local non-Chevrolet shop yet, they asked me to help them source parts
They asked me to help source a new switch. I can't find it in online Chev parts catalogs, found D6249D used on E-bay, 26047377 with no source, and Carquest SAC4665 on Advance Auto Parts with a picture that looks right, but $183.
What says the Corvette Forum wisdom?
Edit: It was the motor or circuit board attached to it.
