What's all required to remove pull timing cover?
I have to remove my HB and Timing cover to replace the cover gasket. Does the radiator and accessories on the front of the engine need to come out or can I just slide the steering rack over? Anyhow know if a good how to for this?
Radiator can stay, you’ll need to move the PS cooler out of the way and the water pump then slide the rack out through the passenger side but it does not need to come all the way out. I’d recommend going with an ATI UD balancer as well while you’re there. Free hp
Supporting Vendor
Once you unbolt the timing cover you should be able to move it away from the block enough to remove the gasket and slip the new one in.
Originally Posted by subfloor@centurytrans
If it's just the timing cover gasket that you're replacing, you don't need to remove the balancer or any of the power steering.
