Trailing Arm Bushing Install Party
Received 1,962 Likes
I decided a while ago that I wanted to swap out my poly rear trailing arm bushings for rubber. I spent the better part of last Sunday taking the rear suspension apart to get the trailing arms out. I figured the install would go much smoother with a bunch of help - so I called upon the best in the area - my buddies Sky65 (Tom Selby) and Bluestripe67 (Dennis King. A last minute invite included Paul Wilkinson who I met a few years ago from the Forum., and who just finished the restoration of his gorgeous 60 you'll see below.
With the new bushings in hand, and the install special tool on loan from "DAN70" (thanks again Dan - today was the day to get 'r done! Dennis & Tom showed up a little before 10 and we got after it and everything went smoothly. Paul showed up @ 11 and offered great supervision! The special tool worked great to not only compress the bushings in, but also to flare the one end of the inner tube.
Right about now Dennis said - "you better be taking some pictures"!!!
Dennis hard at work!
Of course we had a bit of a car show in the driveway (a cyclist even stopped to drool)
I just have to bleed the brakes and install the rear spring and I'll be done! Thanks again for the help today gents - couldn't have done it without you!
Tom
Tom
The following 2 users liked this post by Tom Austin:
Critter1 (05-23-2018),
Frankie the Fink (05-24-2018)
Received 2,127 Likes
Glad to be able to help. We had a good time and acted as if we knew what we were doing. No one would know the difference anyhow. The special tool is easy to use and the results are easy to see. Paul's '60 was NICE Dennis
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Sometimes it takes a village.
You're lucky those gents are close by to give you a hand. well done.
Great idea ! I am sure that all of youse early Corvette loons are looking for an avenue to locally share your expertise and get yer old plastic cars out for a "community service" function. I wish that this would happen more often, start it up in your town, I can rarely repair anything but that won't stop me from showing up and participating. I mean, somebody's gotta' bring some decent beer to these gigs …
Ray
Ray
Good job guys. If y'all want to road trip, mine need changing as well as everything else.
Good job indeed and glad to know the tool worked.
As I posted last week, some previous neer'-do-well put poly bushing in the front of my 63 trailing arms and they crumbled into small hard bits three weeks ago. So, a friend and I will be tackling this job mid-June.....car is undriveable until then.
So - you did the right thing getting rid of that crappy poly.....when they go - they REALLY go...you can see the chunks down in the frame pocket in the second picture.... Resulting in an azz-clenching, carnival ride, 3 mile drive home at about 20mph...
Just be real careful working with that spring on your own. I ratchet strap the front of the trailing arm around the lift's drive-on ramp.....use a "C" clamp and a wood spacer to hold the bottle jack saddle from sliding.....works great with no drama and I won't put enough tension on the jacked up spring to the point it will dislodge the car on the jack stand using the ratchet strap..
I'm sure there are similar methods if working without a lift to ensure safety.
smacota1 (05-24-2018)
Pittsburgh coming up soon....amazing that you got the job done.....considering the help....lol...
Jack
Jack
I want to add something to this story that we discovered that could have created a big problem down the road. With the rotors removed but not indexed, I forgot to do it and the results are below. The passenger side would not go back on flush on the hub. I tried a couple of orientations and found that a very small, almost not seen lip existed 1/16" from the hub face. I had to look very close to see it. The first attempt of mounting the rotor, and holding it to the hub with lug nuts resulted in a very slight wobbling rotor. Since the half shafts were out, spining the hub was easy, so the wobble was clearly seen. If the half shafts had been installed we would have missed the wobble and the result would have been areated brake fluid and deminishing braking ability. Head scratching would then start.
So, anytime anyone takes any rotor off, index it first. Some rotors will be stuck for various reasons, but don't beat on the breaking surface. Once removed, check for any interference. Sand or file any rough surfaces as necessary. We fixed the issue by lightly filing the center of the rotor resulting in a perfect fit and zero wobble. I hope this helps others. Dennis
Good catch Dennis. Thanks for the heads up.
good write up gents and nice to see fellowship amongst the Vette fraternity ! As for the beautiful '60 ....... my fav combo, black, silver cove and red interior !
Received 5,010 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Well, I'm hoping to have it done by then, but you know how these things go! But we can get together then anyhow if time permits. It's only been.....39 years?
