Driver side window goes halfway down Help!!
The windows moved up and down but will not fully go down, it stops half way, I removed the accordian rubber piece in the door shook the red wire hard and it did completly go down, but stopped again when I stopped moving the wire. Anyone know what is wrong. I dont think it is the regulator because the window still oves up and down. Bill you their. Thanks
you either have a loose connector or a broken wire....you can pull that conduit out and the plug for the harness is inside the frame in the off chance its loose, I highly doubt it....anywho....with that pulled out you can see if you can figure out which wire is your issue....if worse comes to worse I have a harness for sale and I am in FLA
I suspect that you can probably fix it once you can see the harness and play around with it...you may just have to pull the door panel
corvet786c (05-25-2018)
It's more than likely the regulator mine went down a few inches and stop and would always go back up put your ear to door if u hear what sounds like broken glass when it moving its the regulator, GM replacement about $165 can get them cheaper on E-Bay
odd that it would work one way and not the other....hmmm
Received 2,705 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
If it is not the regulator it could be a bad relay in the door control module. Do a search and you will find how to fix the module will inexpensive replacement relays.
