Non-ethanol gas
Received 3,290 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
You won't notice any difference between E15 and ethanol free in a stock C7.
Skid Row Joe (05-27-2018)
~Stingray (05-27-2018)
Go Canes!
You wont notice a difference in your stock car for sure. I am unsure if you would in a modded motor. I have used both in my SC motor and did not notice any difference.
I have been running Shell and Costco gas for the most part in my C7 since I got it and both of them are ethanol free here in Ontario. The biggest benefit is fuel economy, you get about 3% better economy with ethanol free fuel. The only negative is that both Shell and Costco premium is only 91 up here, so now that the weather is getting warmer I'm going to use mostly 93 or 94 octane, and there are no stations up here that sell ethanol free 93 or 94. But I'll take the slight fuel economy hit in order to make sure I'm not losing power, as I suspect 91 octane on a 70-95 degree day would result in a few degrees of spark retard at WOT.
For a daily driver, with anything as new as a C7, I don't see a lot of benefit to ethanol free gasoline.
If you store it over the winter, I'd strongly recommend running it close to empty and filling up with ethanol free before storing it.
Other than that, use what's easily available.
I also agree. E10 does produce about 3% lower BTUs which may affect performance and/or mileage in some infinitesimal way, but I doubt if anyone would notice the difference. What's more, E10 is far cheaper, at least in this area. The value just isn't there for my nickel.
That's one area where things are different up here. Because Costco sells ethanol free gas, it also has the distinction of being the lowest priced gas around too. The Costco I buy gas from often sells premium for less than the price of regular everywhere else. So it's a win-win, I get better MPG from being ethanol free and pay less for the fuel to begin with. But I've travelled in the US and have seen ethanol free gas that's priced quite a bit higher than gas with ethanol, and in that case the 3% MPG boost won't make up the difference in cost.
Yes.....I have.One time my station was out of 93,so i bought about 4 gals of 89 pure gas.
Normal city driving seemed ok....did NOT drive it hard just in case.
\db2
\db2
Received 1,401 Likes
Gas mileage will go up some, but not enough to offset the difference in price/gal.
However, since we're talking standard gasoline/ethanol blends that are only between 10-15% ethanol (meaning still 85% or more pure gasoline), the total energy reduction for an ethanol blend is about 4%.
I run Exxon - Mobil pure gas 93 octane in my Grand sport most the time just like I did with the Stingray. Its at the closest top tier to my home. In the Stingray I got 1 mpg better on the hwy. No performance difference. Don't know on Grand Sport yet.
On my very built CVO Road king with 140 Torque and 138.5 HP, 11.5 compression I do get a little better performance out of pure 93. I also do not ping when over 90 degrees out with pure.
And if you were running 100% pure ethanol in your C7, that percentage would be meaningful.
For the past several months the ethanol free 91 has been running around $0.06 cheaper then the E10 91. This morning, they are both the same price at $3.17.
