Altanator mounting bracket on aluminum heads
So I have installed a 383 stroker/with aluminum heads in my C3 and when I went to mount the alternator I notice it is 1 inch off from lining up belt to it .I am using stock alternator and stock bracket .
Has anyone had this issue with aluminum heads .I am wondering if the heads are just shorter and does not stick out as much as the old iron heads did .??????
The mounting hole on heads are the same .
Which heads are you running? I used factory L98 aluminum heads and had no issues.
Received 2,128 Likes
Man that sucks. One inch is a lot. Actually too much for common spacers. Maybe a machine shop can fabricate a spacer / bracket to go between the head and stock bracket.
Trace out the Alt bracket mounting surface and the bolt holes on the head with some white cardboard stock. Take that and some measurements to the shop.
Too far forward, or back? Too far back, just shim it forward til they line up. Then maybe get spacers dabbed so it doesn't look like a stack of washers. Got a pic of the alivnment?
Did you put your old waterpump on? Or did your new engine come with a new waterpump? If the new engine came with it's own waterpump, then you may want to compare with the old.
The stack of washers is to find out how much spacing is needed to get spacers fabbed.
