[C2] Inspect T.O and trans input shaft.
Old 05-27-2018, 01:21 PM
frankgv
frankgv's Avatar
Default Inspect T.O and trans input shaft.
frankgv , Today 11:47 AM
Hello and wishing all a meaninful Memorial day celebration.
Is there a way to inspect or just see the input shaft or T.O bearing in a sbc (64) thru the bellhousing boot or by removing the inspection plate.
Thanks
Frank.
Old 05-27-2018, 03:21 PM
Patrick03
64's Rock!
Support Corvetteforum!
Patrick03's Avatar
I don't think you'll be able to see very much, but you might catch a glimpse. Whatcha hoping to see?
Old 05-27-2018, 04:18 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
only through the boot
Bill
Old 05-27-2018, 06:32 PM
65tripleblack
65tripleblack's Avatar
Not on a C2. Only if you shove a borescope probe in.
Old 05-27-2018, 11:23 PM
frankgv
frankgv's Avatar
Default C2 Inspect T.O and trans input shaft.
I would like to try and very lightly (re)grease the trans input shaft to maybe help slide the T.O bearing. When hot, occasionally when fully depressed the pedal will release with a jerk and jumps the car forward. I have used several clutch set ups through the years but never has this happen.
Old 05-28-2018, 03:43 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
the T O bearing doesn't ride that tight to the bearing retainer so I would be surprised if that is the problem. for no other reason than the risk of getting grease on the disc by accident, I wouldn't try it...
but, there are spray greases that with the tube may be able to reach where you are try to get to, or an extension hose on your grease gun
Bill
Old 05-28-2018, 09:36 AM
DansYellow66
DansYellow66's Avatar
Received 2,615 Likes on 1,947 Posts
It's unlikely trying to lubricate it will solve the issue if your diagnosis is correct. Probably the collar is worn or galled and only polishing it or replacing it will fix that. I replaced my front bearing retainer last year that only had about 3000 miles on it and while not worn to where the diameter had been reduced, I was surprised to see how many score marks and scratches were in it for so few miles. And I always lightly lube it when installing the transmission. I replaced it again just to have a fresh start.
Old 05-28-2018, 03:41 PM
frankgv
frankgv's Avatar
Thanks, the collar you are talking about is the bearing retainer sleeve that bolts to the front of the trans. over the input shaft ??? at least mine does to fit the GM throw out on my 5 speed aftermarket.
Thanks.
Frank.
To Inspect T.O and trans input shaft.
Quick Reply: [C2] Inspect T.O and trans input shaft.
