How water-tight is the convertible top?
I've been caught in the rain a few times and it stays dry as long as I am careful to be sure that when the door is closed, the corner of the glass doesn't get caught on the top fabric.
I'm curious of what the results were of trying to take one through a touchless automatic care wash. Yes, I know that violates one of the Commandments of Corvette ownership, but my garage/driveway is far away from the house and no water spigot is within reach to do it by hand.
Received 19,291 Likes
'20-'21-'22-'23-'24
If you are going to take it to a car wash, I would recommend you use the self-serve type where you can control how hard the water hits the window area and the weatherstripping. That’s what I do and have minimal water intrusion into the cabin area.
Earlier this year, I drove my 2001 Corvette convertible though the car wash (brushes and all) right after getting a brand new top installed to test the workmanship of the shop and it did just fine (no leaks). Interestingly, however, on my road trip to Bowling Green a few months ago, on the way home we got caught in a torrential rain and there was a slight periodic drip from time to time from the driver's side window. I've not experienced it again since. So my take away is that the fitment of the top is likely something very unique to each car and if water hits a seal "just right" it might leak.
I don't think you have much to worry about. I do wash my Corvette convertible in our drive almost all of the time (other than that first test run of the new top through the car wash), another alternative you might consider is the old fashioned wand wash....I've used those before and they do a pretty good job and you are in control of the spray.
Automatic car wash? Do what Vetteman Jack said.
Thanks for the replies.
I'm more concerned with the bottom of the back area, where it just sits on the car. It doesn't look like there is really a seal there.
I'm less concerned with the area around the windows, I think the weather stripping is still soft and pliable, and makes a good seal.
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I wash my car at home. It's a Vert.
It does not leak in any weather. However, if the hose hits the window from the bottom up, as I would suspect a car wash would do, I get few drips inside the car.
I may need to adjust my glass some for a tighter fit, but since it does not leak in a downward rainfall, I am not going to mess with it.
My suspicion is that my interior would not fair well with a car wash, that's besides the fact that the car itself would drag in a conveyor type car wash.
Try it and see what happens. Then you will know.
For me and my 03 vert I will wash it by hand as I have everything I need right by my driveway. It only takes me a few minutes then I blow it off with my leaf blower and wipe it down. Easy peasy!
I don't think I would take it through a car wash that the brushes hit it though. Just me.
03 vert., brushless car wash, few leaks around top side windows. do it your car wash, no leaks, any type of rain, no leaks. no leaks where top meets trunk area. happy camper.
There are some adjustments for the convertible top...
http://www.c5forum.com/forum/ubbthre...te_id=1#import
St. Jude Donor '18
Give up washing your Corvette all together, and purchase the Chadwicks Triple Play system. I used to wash & detail cars in HS. It took me years to convert. But now, I wouldn't have it any other way.
Neither my old nor my new top ever showed signs of leakage where the top meets the deck. I suppose it is possible if your seals are shot or your top not properly adjusted...but I suspect you'd be hearing a lot of wind noise if that was the case. Also, a little bit of water isn't going to hurt your car, so go ahead and give it a test. If you are very concerned, I do think you'd be better off using a wand wash. You can also get the car clean by using a bucket of water. I do that quite a bit- soapy water with micro fiber cloth, followed up with a clear bucket of water and micro fiber cloth, then dry and wax if you like. You do not need a hose to wash a car.
Do yourself a favor and get a couple of long water hoses. However. Its pretty good seal unless your seals are bad/worn out. Ive driven 145mph+ in the vert and the top held up nice. But i say skip the automatic dryer aa it will blow your rear window.
I just squashed the last leak on mine. Since then here is Austin it has been through some really bad rain storms and not a drop of water.
Also like everyone else said only coin operated or hand washed
I've heard about dryers blowing out rear windows on convertible tops. I wonder just how often this actually happens (and when it does happen, if the window is simply on borrowed time). In my case the 17 year old/100,000 mile top's window did not pop out in the car washes, rather it popped out when I was cleaning it by hand. Based on my experience, I'd more inclined to advise fellow convertible owners with old tops to be very careful not to place too much pressure against that back glass while cleaning.
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Build up the w/s weatherstrip where it turns down the pillar. Told the glass installer my problem and he solved it by putting extra stuff in that area.
My '99 vert is on its 2nd top, replaced by the original owner. Absolutely leak free during normal driving and washing. High pressure water, as in a manual car wash with a pressure wand, not automated, will result in a couple drops inside getting by the window seals, but as I said, zero leakage in normal conditions.
