Z06 Cam Install
Z06 Cam Install
Hello,
I am thinking about having a cam installed. I currently have installed, Billy boat headers, x-pipe high flow cars, Billy boat fusion exhaust, Afe carbon fiber intake and ported throttle body with tune. I don't really know much about the process of having a cam installed but love the sound.
If anyone has this installed and went through the process would great to hear of your input.
Also would is a rough shop install cost?
Thank you
Thank you
Former Vendor
If your on the East Coast or in the North East give us a shout, We can get you taken care of
Hello,
Thank you
Thank you
beavisr1 (04-27-2021)
Have you researched shops in CA? If none available, then you have great options in AZ and TX. Keep in mind, whoever you have it installed by AND re-tuned, that it most likely will require you leaving for your car for a few days at least. Are you willing to pay over $6K for the sound? If I was looking at installing a cam, it would be for the drivability, performance increase, and then sound in that order. It sounds like you may want to do some research to help determine what it is that you want. I'm guessing you've already figured out the CA emissions procedures in regards to modified vehicles there.
Well I have my car going into a shop to install the following this week:
Katech K 1 force cam shaft
Katech ported supercharger
Katech ported supercharger snot
Katech ported heads with new lifters and timing chain
PSI high lift valve springs
Katech 103m throttle body
Katech valve painted cover with relocation kit
MSD spark plug cables
Katech spark plug covers
Katech valley delete cover
New spark plugs
Meth kit
Griptec 2.40" supercharger pully
ATI super damper
ATI 15% overdrive supercharger drive pully
Tune of engian and transmission
New spark plugs
Meth kit
ATI super damper
About 800 rwhp going to be a 2-3 week project between when shipping out parts to be ported and put back together.
I currently installed headers, x-pipe and exhaust all Billy Boat with AFE carbon intake.
I’m going to say around 740-750rw on a dynojet. The 2nd or 3rd pull is going to really suck if you don’t upgrade the heat exchanger and/or add a tank to ice it down (but if your doing that, you need to re-route intercooler lines).
John
John
Hello,
Thank you
Thank you
New spark plugs
Meth kit
ATI super damper
New spark plugs
Meth kit
ATI super damper
RPM Motorsports is doing the work.
All parts are here inchdeling the Katech CNC heads with supercharger along snot.
I hope to have it all back with tune by end of next week but wont be able to pick up till Tuesday the 28th as I am out of town.
Katech is such a great company Jason helped out a lot to push the order.
Regards
