'84 warm start issues
My '84 (I'm original owner, 26,000 miles) has an issue when starting warm/hot. It doesn't want to keep running and requires feathering the accelerator for about a minute until it settles into an idle that keeps it going. Almost like it's starving for fuel. This started a couple of years ago and I've replaced the fuel filter twice which seems to help for awhile but I think there is something else going on. The car is totally stock with the cross-fire system all intact. Any others with this problem? Fuel going bad from extended storage? Ideas?
Zen Vet Master Level VII
Your sensors is sending signals to your computer that your engine is hot when it is cold and cold when it is hot. That wrong information really screws up you rich/lean setting, hence why your engine runs poorly.
If you settle to a high idle I would definitely agree it is the CTS. Tou cold also have a fuel pressure issue or even maybe an O2 sensor. However the O2 sensor only helps in closed loop and even then it is little. There was a gentleman who's car ran decent with it unplugged. If you have the means to make a wire for winaldl to view live data that also will help. Both suggestions are right and good places to start.
It settles to an idle of 600 RPM, so definitely not high. Coolant temp reading seems to be correct/normal from cold start to operating temp. Fuel pressure and/or O2 sensor sound like the possible culprits. After 35 years of ownership I suppose it's time to have some issues. Thanks!
