[C2] Power Window Conduit 1965 Coupe
Old 06-22-2018, 04:07 PM
SolarVet
SolarVet's Avatar
Default Power Window Conduit 1965 Coupe
Working on my 1965 and noticed the power window conduit on each side only has one screw in it attaching it to the door. I ordered replacement screws but noticed they are different than the ones that were in the door. When I took the one out that currently exists in the door I hear something fall (perhaps a clip inside the door). Power windows are an original option on the car.
So the questions are:
1) There should be two screws that attach the conduit it to the door (not just one) Correct?
2) Is there a clip inside the door panel that the screw threads into?
3) Which of the screws shown in the picture are correct?
Thanks - Hunter
Old 06-22-2018, 04:50 PM
leif.anderson93
leif.anderson93's Avatar
Received 3,090 Likes on 1,859 Posts
I don't have a '65 TIM&JG handy, but the '67 TIM&JG calls for "zinc plated hex recessed head screws with shoulder washers" which would describe the parts you received. However, my '67 with factory power windows have black phillip head screws like you currently have. I'll wait to hear from those with much more "eyes on" experience to chime in.
SolarVet (06-24-2018)
Old 06-22-2018, 05:17 PM
emdoller
emdoller's Avatar
Here’s my 67. No clip on inside of door.
Old 06-22-2018, 07:34 PM
65hihp
65hihp's Avatar
Received 3,263 Likes on 1,686 Posts
Here is 64, hex head shouldered screw. The 65 JG calls for the same.
Two of them. Probably no clip to screw into.
The following 2 users liked this post by 65hihp:
jbrinsfi (06-23-2018), SolarVet (06-24-2018)
Old 06-22-2018, 08:18 PM
65 Pro Vette
Support Corvetteforum!
65 Pro Vette's Avatar
Received 1,041 Likes on 573 Posts
C2 of Year Finalist (appearance mods) 2019
There are no clips inside the door of original power window cars and there would be two holes drilled in your door for the screws. What makes you think it’s a factory power window car? They’re very easy to add.
Old 06-22-2018, 08:56 PM
leif.anderson93
Don,
Satisfy my curiosity for me. The AIM shows screw (187822) and nut (445138) to attach the conduit assembly. LIC sells the parts listed below to attach the conduit assembly. Thoughts??
https://www.parts123.com/parts123/yb...5Z5Z50000370a#
Old 06-22-2018, 09:13 PM
R66
R66's Avatar
Received 1,531 Likes on 1,033 Posts
R66 has two hex head on the RH door, but only one hex head on the LH door. Can't see a hole drilled for the second screw on the LH side. 51 year old car, can't help more that that.
Old 06-22-2018, 09:16 PM
emdoller
emdoller's Avatar
Old 06-23-2018, 08:57 AM
woodsdesign
woodsdesign's Avatar
I will be following this thread closely as us I will be adding PWRs to my 65 coupe very soon.
Old 06-23-2018, 11:08 AM
mark6669
mark6669's Avatar
All of the original PW conduits I have removed 1 screw went into the metal hinge reinforcement the other went thru the glass into a metal retainer.
Mark
Old 06-24-2018, 10:13 PM
SolarVet
SolarVet's Avatar
Thanks 65 ProVette. I have the original window sticker and it shows power windows.
Old 06-25-2018, 03:38 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
An old mechanic's trip to deal with a wallowed out screw hole was to stick something in there to let the screw "bite" again. I've seen paper clips used, a bit of solder or finishing nails. You prob heard some Bubba fix like this falling inside the door. The incorrect screw you removed is prob a larger size for the same reason.
To Power Window Conduit 1965 Coupe
Quick Reply: [C2] Power Window Conduit 1965 Coupe
