Dash malfunction
Dash malfunction
When I started the car everything was fine, I hit the blinker then I noticed the windshield display showed both blinkers and headlight indicators stay on. The gauges are working but the instrument panel lights are not. Headlights will not come up. It also read it was running hot. When I turned the car off I noticed a loud clicking noise that sounds like it's coming from under the passenger headlight. The clicking has continued for days. Any suggestions?
Codes
10-pcm
p-1539hc
28-tcs
c1226h
c1296h
40-bcm
b2578hc
b2583hc
58- no codes
60 ipc no codes
bo-rfa no codes
a-6-scm no codes
a1-rdcm
b2283h
b2285
ao-ldcm
b2252h
b2282h
b2284h
80 radio no comm
99 tvac no codes
p-1539hc
28-tcs
c1226h
c1296h
40-bcm
b2578hc
b2583hc
58- no codes
60 ipc no codes
bo-rfa no codes
a-6-scm no codes
a1-rdcm
b2283h
b2285
ao-ldcm
b2252h
b2282h
b2284h
80 radio no comm
99 tvac no codes
If this is separate from this thread's original issue, as posted back in June, I would suggest opening a new thread to avoid confusion and get better help.
I also noted the original thread was left open-ended with no final results. Did you solve the problem following the suggested process? It would benefit others if they could read your feedback. Thanks.
