C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
2008 C6 Z - Car starts, then shuts off and the windows will not roll up
Old 06-28-2018, 08:55 PM
BurnoutFilms
BurnoutFilms's Avatar
Default 2008 C6 Z - Car starts, then shuts off and the windows will not roll up
My C6 Z will start but then shut off shortly after. It is throwing a p0161 code for the MAP sensor. The windows will also not roll up and there is an occasional “fob not present” message. Is there any way to remedy this? Any ideas what’s going on? Thank you in advance, guys!
Old 06-28-2018, 09:56 PM
03BlkZ
Support Corvetteforum!
03BlkZ's Avatar
I am not sure about the MAP sensor issue but the rest of the problems sound like a bad battery. When I unhooked my battery for maintenance the windows needed to be re indexed. Search the procedure for th window reminded. It's simple. But i would have your battery checked.
Old 06-28-2018, 11:22 PM
BurnoutFilms
Thank you for your advice! I’ll be sure to check that tomorrow and I’ll update the thread. If anyone else has any other tips feel free to let me know!
Old 06-29-2018, 11:05 AM
dmuellenberg
dmuellenberg's Avatar
Along with the car battery, also check the battery in the FOB. I have been needing to replace the FOB battery every 2-3 years.
Old 06-30-2018, 01:08 AM
Innovate
Innovate's Avatar
When battery juice gets low mine does this and it is irritating. Also test the alternator.
Old 06-30-2018, 06:37 AM
BurnoutFilms
So far:
We were able to fix one of the window issues (passenger side) with a diagnostic computer. Just manipulated it with the computer and it worked fine. The drivers side turned out to be the window motor.
After we we replaced the battery, which did end up taking care of a lot of issues (thank you all for your input) the car would crank but still not start.
Fuel is is still getting cut off to the motor and we are beginning to believe it is the ground connection to the PCM. We tried using starter fluid to get the car started, and finding vacuum leaks (weren’t any). Once we re-ground the PCM I’ll update and go from there. Thank you all again for your help!
Old 07-13-2018, 03:11 PM
BurnoutFilms
There was a crack in the Intake manifold
Old 07-18-2018, 03:48 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Weird...OE manifold? You can find a good used on on here fairly easily...or just upgrade to an MSD or FAST.
Old 07-18-2018, 04:05 PM
BurnoutFilms
Yes sir,
OE manifold already dropped a new OE one in
03BlkZ (07-18-2018)
Old 07-18-2018, 06:54 PM
03BlkZ
03BlkZ's Avatar
Where was it cracked and how do you think it happened? Did this solve your issues?
To 2008 C6 Z - Car starts, then shuts off and the windows will not roll up
Quick Reply: 2008 C6 Z - Car starts, then shuts off and the windows will not roll up
