Racing (like) seat belt harness or bar behind seats
Who has put together something short of a roll bar to put performance racing type seat belts in a C2? Interested in ideas. Thanks.
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
It's not really a good idea to have a racing harness (meaning shoulder straps in addition to the lap belt) unless you also have a roll bar. Reason being that if you go upside down, that harness will keep you upright in your seat and your head will hold up the car.... for a while, anyway.
Roger Walling (07-14-2018)
Regardless, I believe adding any such restraint system to an old Corvette gives a false sense of security and safety. There is no (practical) way to know ahead of time that you are actually better off.
Jim
I'm not a fan of adding even a 3 point belt/harness system to an old Corvette. Yes, I think it would have the tendency to do the same thing a full racing harness would do. I also think you could argue that you could tilt sideways (if you have the time!) and avoid being trapped upright.
Jim
Jim
Interesting. So I have an SRIII frame, LS3, and C6 suspension all the way around. I can "track" the car at several places and want to do high speed auto cross (like the Good Guys events). Most folks say I need at least a factory 3 point harness like a newer corvette. I know I can do that, but was looking for a way of adding a little more safety, but if not practical (without a full SCCA roll cage), I will have to do what the factory type set up.
Have you ever been on track in a car with only a 3 point harness? I have and it was the scariest ride of my life. 3 point harnesses do nothing to locate you laterally and there is no anti-sub provision. You'll get tossed around every time the car changes direction. That's bad enough if you are a passenger but if you are driving, you'll have a hard time maintaining vehicle control.
5 (or 6) point racing harness will keep you located and you'll be better able to control the vehicle. And, trust me on this, no matter how chest-compressingly tight you make the belts in the paddock, after you go around turn 1, you'll be reaching for the straps to make them even tighter. I guarantee it.
Jim
An SCCA cage means different things to different people. If you intend to drive the car on the street, I can understand why you wouldn't want a cage with side bars, forward down bars, etc. However, since you say you do want to track the car, IMHO, you really, really ought to consider a roll hoop with rear bracing (like in the pictures), a harness bar, and laterally triangulated bracing. This would be the minimum amount of roll protection I'd accept in any car I planned to track.
Jim
Jim
Interesting. I will consider the bars like in the picture. The guys I speak to (who own stock newer corvettes) "track" their cars with the factory seat belts....and they run them pretty hard. I know they aren't racing, but the drive them relatively hard. I need to consider what I really want to do with this thing once I get it running and ready for the road. I will consider the points you've made.
2019 Corvette of the Year Winner
St. Jude Donor '15
this was made removable to allow the car to be taken apart and put back together again.
I don’t have other photos right now as I am in Maine and the car is in my shop in Ohio. I will be back next weekend and can see what other photos I have. The guy that fabricated the roll bar was http://rollcageguy.com/
He makes sure that he adheres to rules of the sanctioning body. He has a small shop but does a really nice job as you can see. I took my car to him and after about 4 to 6 weeks he called and said it was completed! He had some other C5’s there where he was putting full cages in them for running one mile shot outs...cars had twin turbos!
I was was really pleased with his work and even more pleased with the cost....under $1,000!
St. Jude Donor '15
Don’t forget those new Corvettes have other things like crash crumble zones, side bar impact rails, air bags....in your restomod you only have your seat belt! Big difference!
I can appreciate those obvious points, thanks. My perspective in posting this is to explore options based on my parameters. As you can imagine, I am not trying to make the car new or a race car. I am looking for some perspective based on points of view of those who have done or really looked at doing what I am trying to do (at end state).....to tell you the truth, I am trying to see what folks' thoughts are on "good enough"...Thanks for the info on the roll bar.
After sliding around the seat for years while auto crossing my 67 convertible, I installed a belt bar behind the seats. I copied what a friend had done to his 67 ragtop. Now the 4-point belts hold me tightly in the seat and cut my times several seconds per lap. I had a performance auto shop fab it up for me. I've run in hundreds of auto crosses over the past 13 years and have never seen a car flip onto its roof, although I suppose it's theoretically possible, but the chance is negligible --- esp. for a low car like a Vette. I would definitely not use these belts to track a car around Laguna Seca!
Lou
Lou
The following 2 users liked this post by LouieM:
Loren Smith (07-12-2018),
wmf62 (07-12-2018)
Lou
Lou
Lou
I had 5 point harness in my street car and took them out because of that same reason.
Besides that, you can not turn around to see things with the 5 point.
