1970 coupe removable top storage
I have searched the threads and still can't seem to figure out how my '70 tops are stored in the rear compartment. The owners manual has what I think is supposed to be an illustration of the storage method at the bottom of page 35 but it is too dark in my reprinted version to see clearly. Does anyone have an original that they can post? '71 is different with the "Y" strap. The '70 has two straps, one on each side with adjustable clasps and clips on the ends. Manual says "Place the panels in the rear stowage compartment against the sides and secure them with the retaining straps".
Left side
Right side
Left side
Right side
Take the T-tops off and place them on the floor of the storage compartment exactly like they are placed on the top. Tie them down with the 3-point strap system. Drive on...
Is is better for the tops to be placed into individual (vinyl) storage bags, but not absolutely necessary. If you don't put them in bags (or a special case), some protection on the underside of the straps/buckles would be a good idea.
Generally, you don't drive far enough with them off to go to the trouble of storage. If the weather is not assured of being rain-free, I just don't take them off. If weather is good, I just leave them at home.
tomboyy (07-18-2018)
I had a '68 with 3-point strap, also. I think you might be missing one of the sections of strap or some of the hardware.
i've always placed them on top of each other in the vinyl bags then tied down with the "Y" harness strap in my 72.
always seemed funny as there was then a lot of wasted space for putting other things back there...
you learn something new about these cars every day
It make sense that they would be the same from 68 on but don’t understand why my 70 has the two adjustable straps with clips or hooks at each end and not the “Y” strap. It also doesn’t have the center loop for the Y strap to attach.
Going to pay attention to other ‘70s I see at Carlisle this year.
That said the straps are missing from my car altogether.
More information on tie down straps configuration
I went to the assembly manuals for '68, '70, and '71.
'68 and '70 are the same
Note how the roof panels are oriented.
'71 used the "Y" strap
Cavu2u (07-19-2018)
In a '70, the roof panels are placed in the rear at about 45 degree angles. One at each side. You place the roof panel in the 45 degree position enough to expose the connector on the floor. Connect the strap to the floor connector and tighten the strap to secure the top.
See the pictures below, the straps are connected correctly. Just that the roof panels are not there.
The following 2 users liked this post by Barry's70LT1:
John Parodi (11-27-2022),
knightvd (07-23-2018)
