A8 Tranny - Have they fixed it?
Old 07-11-2018, 10:49 AM
CorvetteRL
Lifetime Vette Lover
Support Corvetteforum!
CorvetteRL's Avatar
Default A8 Tranny - Have they fixed it?
So, all the info on the A8 issues - has Chevy fixed the problems in the 2018 or 2019s?
Thx!
Old 07-11-2018, 10:55 AM
Thunder22
Thunder22's Avatar
Received 2,311 Likes on 1,456 Posts
I didn't have any problems with my 2017 so there's that.......
Old 07-11-2018, 11:00 AM
saleen556
saleen556's Avatar
Received 2,202 Likes on 1,193 Posts
I wouldn't worry about the issue if you want an auto. The issues are rare if you consider how many are sold. You just hear about issues more on the internet as people vent about them.
The following 4 users liked this post by saleen556:
beaversstonehaven (07-13-2018), jimmie jam (08-15-2018), robert miller (07-20-2018), woodsguy (07-20-2018)
Old 07-11-2018, 11:02 AM
Kevin A Jones
Kevin A Jones's Avatar
Received 11,573 Likes on 5,554 Posts
There was communication that it was fixed during the 2017 model year production (can't remember right now what the exact build date was)
however that certainly doesn't mean that no car after will ever have an A8 issue. My 2017 GS has been problem free.
911Hunter (08-20-2018)
Old 07-11-2018, 11:04 AM
sunsalem
sunsalem's Avatar
Received 2,146 Likes on 1,521 Posts
A8 is fine...buy with confidence.
Chevette!?!? (08-20-2018)
Old 07-11-2018, 11:07 AM
Patman
Patman's Avatar
Received 1,918 Likes on 1,190 Posts
I have 5600 trouble free miles on my 2018 so far and I let it go into V4 mode all the time as well.
Old 07-11-2018, 11:29 AM
2kvetmy
2kvetmy's Avatar
I have 18000 on my Aug 2016 build date / 2017 with no problems
Old 07-11-2018, 11:35 AM
davepl
davepl's Avatar
Received 1,500 Likes on 987 Posts
No problems here with my A8... but then I have a Z and the problems I saw were all in Stingrays, so...
Old 07-11-2018, 11:38 AM
ExRedRacer
ExRedRacer's Avatar
Received 1,029 Likes on 549 Posts
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Just turned over 14,000 miles on my 2016 Z51 with a build date of 1/16 and have had zero problems. It runs flawlessly. I do have the Range device so it's always in V8 mode and that might have something to do with it.
Old 07-11-2018, 11:46 AM
Mike Mercury
Mike Mercury's Avatar
I have 8k miles on my 2015 that was built on day two of production. No problems yet; though last month I installed that "Range" module.
FYI... the highly reported issue is actually with the torque converter... and not the A8 transmission; though I see that some vision them together as a single unit.
robertbruce (07-12-2018)
Old 07-11-2018, 12:00 PM
iclick
iclick's Avatar
Well, the A8 as a complete assembly has documented more issues than just the TC, like delayed engagement and intermittent hard shifts. Like the TC problem the former requires pulling the tranny to fix (replace stator and add some o-rings), but the latter is usually fixed by a software reset and relearn. I was lucky and my 2015 had only the first two issues , but only the TC was repaired since I could never demonstrate the delayed engagement problem to a dealer service rep. This was even though the tranny was already out of the car. I threw in the towel two weeks later, as I've lamented more than once in the past.
Old 07-11-2018, 01:12 PM
Rebel Yell
Rebel Yell's Avatar
Received 2,639 Likes on 1,702 Posts
My '16 A8 (3/16 build) has been just fine. And, the bad transmission threads have become less, and less.
Old 07-11-2018, 01:32 PM
kaplana08
kaplana08's Avatar
Default 2019
There was a report about a bad torque Converter on a 2019 right out of the box reported on this forum a couple of weeks ago.Research it.
Old 07-11-2018, 01:53 PM
teenVette
teenVette's Avatar
So far so good with my ‘16
Old 07-11-2018, 02:02 PM
Glenmcp
Glenmcp's Avatar
My 17 Z06 A8 runs just fine. Forums are a magnet for problem reports.
Old 07-11-2018, 02:09 PM
jonebone
jonebone's Avatar
My A8 is fine. One trick people recommend is to put it in manual and shift 1 2 1 before driving off in the morning. This is easy for me since I live in a long driveway and I like to go slow when leaving to keep the car as clean as possible.
My point being, even if yours wasn't fine, there is a workaround.
Old 07-11-2018, 02:16 PM
dfettero
dfettero's Avatar
Default 33K miles on 2016 A8
33K miles on 2016 A8 with NO issues.
Thx!
To A8 Tranny - Have they fixed it?
Old 07-11-2018, 02:29 PM
PegasusCapital
CF Senior Member
PegasusCapital's Avatar
The best way to "fix" the A8 problem is to defeat AFM from forcing the engine into V4 mode. Lots of posts on this topic. Spend $200 on a Range Technology unit and you'll be worry free. It's a great transmission otherwise.
The following 2 users liked this post by PegasusCapital:
911Hunter (08-20-2018), Mike Mercury (07-11-2018)
Old 07-11-2018, 02:36 PM
netster
netster's Avatar
18,500 miles on my 2016. No problems so far.
Old 07-11-2018, 03:26 PM
japc5
japc5's Avatar
I just broke 5000 miles on my 2018 GS and have had no issues with the A8 or the car for that matter.
JDMilw (07-14-2018)
Quick Reply: A8 Tranny - Have they fixed it?
