FS: ZR1/LS9 McLeod RXT twin disk clutch assembly
According to McLeod, it is 1000hp. They do make a 1200 hp rated one now, I see, that uses a stronger pressure plate.
Part number of the one I have is 6976-07M.
This clutch originally sold for $1200, and is specific to the LS9/ZR1 flywheel/slave assembly. This does not include a flywheel. It is designed to work with the OEM LS9 flywheel, and will NOT work with an LS3 or LS7 setup. It was only used for 50 miles, when there was an engine issue, the engine was pulled, and it was never reinstalled in the car. It was professionally installed and removed. Car never saw track duty or any hard use on the street. There is no bluing or scorching on the disks, pressure plate, or floater plate. Clutch only has the normal ceramic friction wear that immediately takes place during break in. If there is interest in this, I will take detailed pics.
Looking for $500+ship, but would give a discount on a local pickup in metro Detroit.
