TING ! ... click , tick , tick .....
Old 07-12-2018, 07:29 PM
C409
C409's Avatar
Default TING ! ... click , tick , tick .....
..... … A most dreaded sound in the shop when trying to insert the wrist pin retaining circlips in your new pistons ! …..
Old 07-16-2018, 11:47 AM
C409
C409's Avatar
….. I got them ALL installed without losing a single one ! …..
Old 07-16-2018, 01:55 PM
Dt86
Dt86's Avatar
At least you found it! Parts always fly off to the most challenging locations for me.
Old 07-16-2018, 02:32 PM
84 4+3's Avatar
Received 1,373 Likes on 1,061 Posts
I lost one. Luckily I had an extra.
Old 07-16-2018, 02:41 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
Lol....those suck when they go flying! Gotta keep a finger over 'em as you push 'em in.
Nice job, and nice looking new pistons!
Old 07-16-2018, 03:44 PM
kael
Support Corvetteforum!
kael's Avatar
Finalist 2020 C4 of the Year - Unmodified
Sometimes, when I remember, I'll drape a towel where the flying part is likely to go. Especially when clipping a good sized bolt in half. Otherwise, might have to redo some drywall.
Old 07-16-2018, 06:54 PM
DGXR
DGXR's Avatar
I remember years ago, an experienced mechanic told me to be careful when removing the retaining clip (u-joint or something else I forget) because "it will go flying into space." LOL
Old 07-18-2018, 08:05 AM
C409
C409's Avatar
….. Getting ready to load 'em up ! …..
Old 07-18-2018, 08:08 AM
C409
C409's Avatar
….. Note all the holes drilled into the crankshaft's counterweights … it took the machinist a long time to balance the crank to the bobweight needed for my light pistons and titanium rods …..
Old 07-20-2018, 06:22 PM
C409
C409's Avatar
….. Setting ring end gaps … PITA even with this fancy grinder … grind and check clearance 4-5 times per ring x 16 rings …..
cardo0 (07-20-2018)
Old 07-20-2018, 09:36 PM
TravisSchoech
TravisSchoech's Avatar
What rods are those? Modified LS stuff?
Old 07-20-2018, 10:51 PM
C409
C409's Avatar
..... Yessir ! … LS7 rods , massaged to work in the Gen 1 Dart block … the wrist pin bushings were honed from LS .925" to sbc .927" … length is 6.067" , so I used a 3.875" stroke crank with pistons intended for a 4.00" stroke that have 1.000" compression height … the new pistons were custom ordered with a .990" CH because the block had been zero decked in a former configuration … new piston to deck is -.005" … this makes for a 421ci engine …..
Old 07-20-2018, 11:19 PM
TravisSchoech
That's pretty damn impressive.
what kind of power are those rods capable of handling?
On a side note, based on your profile pic - I can only assume you're used to a bit of power.
What are your thoughts on the tq/hp limits of the stock crank/rods in a gen 1 sbc from an 88'?
Old 07-21-2018, 08:47 AM
C409
C409's Avatar
….. Thanks ! ... Per the Wallace Racing ET/Weight/MPH calculators , my junk was making around 600hp … THIS version will go on the engine dyno for more accurate readings … according to Katech , the LS7 rods have lived through 700+ hp … stock bottom end in a 350 should support 500 depending on how its set-up and used … but it would be on the edge ! …..
Old 07-21-2018, 01:48 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Nice build. Keep us posted.
Old 07-21-2018, 02:53 PM
C409
C409's Avatar
….. … Skinny rings 1mm 1mm 3mm … Thank God and ARP for the piston funnel ! …
Old 07-21-2018, 02:58 PM
C409
C409's Avatar
….. Degreed the cam today too ! …..
To TING ! ... click , tick , tick .....
Old 07-22-2018, 01:42 PM
confab
confab's Avatar
lol.. I know! OMZ!
Anything that goes under my bench is GONE.. I dunno what dark force disappears things there, but it's hopeless. Like a bag of holding. I think my record for a snap ring is out the door and somewhere in the middle of the parking lot! lol.
Nice pistons. I have been looking at stroker parts.
I know you're a racer, but do you know how well stroker pistons hold up on the street with that gap in the oil ring land? Special rings there? Anything you have to do out of the ordinary?
Old 07-22-2018, 03:12 PM
1985 Corvette
1985 Corvette's Avatar
House next door might be going up for sale soon, Bob.....sure would be nice if you moved the speed shop up to Jax.
Old 07-22-2018, 04:47 PM
Purple92
Purple92's Avatar
..... Yessir ! … … this makes for a 421ci engine …..
How does that old expression go - "There's no replacement for displacement".
Very nice looking bottom end !!! Smart to use a Dart Block. OEM blocks are just fine for 99+% of the cars out there - but the factory has just cut too much metal out of the blocks to save weight. For serious power - the aftermarket blocks are worth it !!!
Please post dyno curves when you get them,
Quick Reply: TING ! ... click , tick , tick .....
