Chrome paint for front grilles
Hey everyone
I want to paint the black (plastic) front grilles on my 77.
Do you guys know what's a good chrome paint for this?
I know that it won't be the same as real chrome but I don't like the grey/black grille color.
Just wan't to try and if it doesn't look good I will paint it black again.
Why don’t you try the chrome plating kits that are out there. The results will surprise you.
https://www.eastwood.com/eastwood-li...base-coat.html
There are more and some are a miniature version of the professional way real chrome is applied.
All of the craft stores (Hobby Lobby, Michael's, etc) have silver leaf and gold leaf pens (actually like high quality paint markers). The silver works well to simulate vacuum-plated "chrome". Clean the surfaces well before using; and you might want to put a couple of coats of clear (or semi-gloss) lacquer on top to help preserve your work. The marker tip will eliminate the need of masking for spray paint.
oldgto (07-14-2018)
Plus you can get the egg crate effect where the grilli is black or argent with chrome edges.
I've used a couple of versions of the silver leaf pens to paint the raised rib outline around the center panel of my '77. It works pretty good for that purpose but it doesn't last. It takes 2 or 3 coats to cover the black, it's tedious, and it also doesn't look anything like chrome except in color. It's closer to just flat silver paint. If I was going to paint grills I'd spray with a good brand of silver paint - Duplicolor or whatever - and clear coat with gloss.
Received 3,219 Likes
I'd do what 7T1 recommends as far as the silver leafing- I used the Krylon
The center grill from the factory is all black- looks unfinished as the sides are chrome,
Since I'm not a NCRS guy- I wanted it to match the sides with out big money to chrome.
I glass beaded the grill- Sprayed with some primer and then a couple of coats of semi-gloss black. I then got a silver leaf pen (on line for less then $10) and did the edges. Was really easy to do. let it set-up for a few days and buffed it out gently.
I then clear coated it
Richard
Richard
dmaxx3500 (07-15-2018)
Richard
Richard
Is there something to bear in mind, when choosing a clear coat? Different types, chemical reaction with the paint that it is applied on, ...?
For my 73- the grille is metal (albeit pot-metal)-
I sanded the edges with a belt sander- painted black- re-sanded the edges and then cleared it.
I did the same thing to my front grille about 4-5 years ago. Just didn't like the center grille sunk down in about 4 inches. Made some 4" [post] extenders and used the technique I [and Richard} described above. Here is the result:
Search the C3 general forum for: show us your no or low cost home made do it yourself stuff C3 corvette. Go to post 124. You will see step by step procedure.
