Fuel Pressure Numbers
Old 07-14-2018, 01:54 PM
belairbrian
belairbrian's Avatar
Default Fuel Pressure Numbers
92 LTI, with Bosch IIIs.
Just installed a new Delphi with Strainer, removed pulsator. New GM fuel Filter.
After 5 ignition cycles 22 psi but it holds steady for a half hour.
Running is 38 (so slightly below what the FSM calls for). 56 with FPR disconnected No fuel in vacuum fitting.
As soon as you turn car off drops back to 22 psi and hold. Eventually drops to 10 after about 2 hours.
Little bit of a stumble at idle, hot days in traffic.
Is it time to replace the regulator?
Old 07-14-2018, 04:21 PM
C409
C409's Avatar
….. Engine off fuel pressure will have ZERO affect on hot engine idle …..
Old 07-14-2018, 09:08 PM
pcolt94
pcolt94's Avatar
36 to 38 is fine when idling.
56 is high with the vacuum line disconnected.
Either the pump is putting out to much pressure or there is a restriction back to the tank for the return flow
With the vacuum line connected and you rev the engine half throttle for a second the pressure should jump to about 40. If you are much higher than this there might be too much instant pressure for the injectors hence making it to rich causing a stumble. Just a theory
Old 07-17-2018, 01:59 AM
Batman35
1st Gear
Batman35's Avatar
Hey guys new here and new vet owner got a 92 I’m having problems I’m getting around 34 pounds pressure starts and runs for a while heats up and dies not sure have replaced fuel filter and regulator not sure what next thinking injectors the ones in it the resistance on them is all I’ve from 11.93 to 12.21 any ideas ??
Old 07-17-2018, 08:07 AM
aklim
aklim's Avatar
Received 2,225 Likes on 1,939 Posts
I would turn the car to run and see what the pressure spikes to. See if it holds. Tape the gauge to the glass and do a WOT run and see if it holds pressure.
As to the injectors, if they are Multec, dump them. With ethanol, it could be an issue since the coil windings and ethanol don't get along and you will be forced to go to gas stations that have 93 octane 100% gas which will be a PITA.
To Fuel Pressure Numbers
Quick Reply: Fuel Pressure Numbers
