74 Speedometer issues
My speedometer needle was bouncing for a while then stopped working entirely. I replaced the speedometer cable (what a pain in the butt that was) and it's still not working. The needle does move so I'm pretty confident it's not an instrument issue.
Now I'm wondering what this is and if it could be the issue:
Any input is appreciated!
Thanks
Thanks
Received 2,127 Likes
It appears to be an old transducer. When different gear ratios are used, quite often simply changing the "driven" gear in the tranny will recalculate the speedometer. But in extreme ratio changes, say from a 2.73 to a 3.73 the "drive" gear has to be removed. Now we are talking removing the driveshaft, removing the tailshaft housing and swapping out the gear, not fun but do-able.
Along comes the transducer. It compensates the new gear ratio with a lot less labor. The input cable spins at a different rate than the output, thereby getting the speedometer pretty accurate. They are available at Speedo-World and some math is involved for proper selection.
remove it and the plastic driven gear and check if the driven gear has broken or missing teeth and check if you turn the input to the transducer that the output turns.
Thanks
Thanks
To remove the adapter remove the single bolt on the flat plate that holds the adapter to the gearbox. Pull the adapter out and away from the gearbox. On the end of the adapter will be a plastic gear. My guess this gear is worn. Get a correct replacement gear from any of the major corvette parts suppliers (be sure to get the same color gear as the one you remove) and reinstall the adapter. That will likely fix the problem but if not then you know the issue is with the adapter or with the mating gear inside the gearbox.
