Broke off caliper bleeder
I managed to rebuild three out of four calipers correctly yesterday, but on the fourth one I broke off one of the bleeders. Is there any trick to getting that thing out of there? Is there any place that I can send it that will do it reliably and cheaply?
Scott
Scott
you cannt get a vise grip or 6 point socket/wrench on that?
ScottEwine (07-15-2018)
After consideration, a younger me would have spent about 6 hours trying to get it out and eventually screw it up, an older, wiser me will take it to autozone and swap it out for a new one for $64.99.
Does anybody know if the new ones have the new style pistons and o-rings. Should I run the replacement as is or pull it apart and rebuild it with the newer style kit!
Thanks,
Scott
Thanks,
Scott
If you have an arc welder, you could tack-weld a rod with 90* bend to the end of that bleeder, then just back it out. I know you bought another caliper, but thought others might want to know.
Received 1,245 Likes
Thanks,
Scott
Thanks,
Scott
What seals did you install on the first three?
I agree with your evaluation; one reason I might try to save the caliper is because of reports of less-than-adequate rebuilds which leak....and if yours was actually good.... then, since I have a welder that I might try welding a nut on there to unscrew it.
Thanks,
Scott
Thanks,
Scott
Scott
That is kind of what I was thinking. Not sure if they still make the castings anymore but you would think if they did they would know that if they are not sleeved they will soon be leaking. The calipers I pulled of my '69 25+ years ago were sleeved and I just assumed any car that was on the road nowadays would have them and thus any cores would as well.
Just to relate a story about a place that was once and maybe still is supplying chain stores, Let's say his name is say, Carl and is from various addresses in FL. Buyer beware as some calipers sold as rebuilt were nothing more then worn out cores repainted. Originally the calipers were just bored out cast iron, SS sleeving caught on in the late 70's there were plenty of shops with a Bridgeport mill rebuilding them at the time. Few are left.
Mike
ScottEwine (07-16-2018)
stainless steel sleeving is an aftermarket solution to one of the design problems of c3 brakes.
a rebuild should mean fresh seals and cleaned up pistons on a spotless bore wall that has been cleaned up and sanded down with various grits of paper and emory cloth.
no reason that the chinese rebuild houses would resleeve a bore unless they had to. and then who knows if it would be stainless steel.
only the aftermarket suppliers that advertise stainless steel sleeving would guarantee that
ScottEwine (07-17-2018)
Its funny how age does that to us. Unless you have unlimited time (and the money to repair self induced screw ups) I find that just buying a new one is best nowadays. I totally admire the guys who take the time to rebuild the small stuff like steering gear boxes and brake calipers, but Im just at a point where Id rather spend a small amount more for a rebuild from a box store.
I would heat it with a MICRO torch and hit it with FREEZE OFF, then use an easy out.
Last case drill it and re tap it.
Sometimes it's the challenge to do the repair... just my thought...
I do that routinely,....but I don't use a MICRO torch. If you can get it hot enough, it will be out within 5 minutes.I also put never seize on the threads ONLY. Keep it off the sealing taper and you will never have this problem again.
