Blow out clip install
The passenger window in my car is missing the blowout clip. I have a FRC and don't know the process to install a new one. Is this documented anywhere?
Hi, read this thread. It should have all the details!
https://www.corvetteforum.com/forums...ts-of-pix.html
Cheers!
Cheers!
The weatherstripping and the window channel were glued together by the PO I assume. Should I strip these two completely then re apply the weatherstripping OR just reseal them together with a little bit of new windshield urethane?
Received 8,928 Likes
If you change weather stripping make sure you keep the blow out clips as they aren't available any more. I had the windshield in my C5Z replaced in 2007 which ended up ruining the weather strip when they replaced it they didn't carry over the blow out clips from the old weather strip. Car was only 4 years old and the clips were no longer available.
Bill
Bill
The car was missing a blow out clip that why I'm doing this right now. My issue is do I I need to completely disassemble the retainer and rain channel preced and glue them back together?
