Engine not happy!
Old 07-16-2018, 02:02 PM
corvettedave383
corvettedave383's Avatar
Default Engine not happy!
engine aint so happy, any clues on what my knocking noise might be, ive got some idea's, getting a 2nd opinion??
Old 07-16-2018, 02:49 PM
C3 Stroker
C3 Stroker's Avatar
Originally Posted by corvettedave383
https://youtu.be/CamKk8kt3N8
Mine sounded exactly like that and the outcome was not good.......could be something as simple as a loose rocker, or very bad like a rod, spun bearing, chipped piston....etc. Open the valve cover and go from there.
Old 07-16-2018, 03:30 PM
stingr69
stingr69's Avatar
Received 1,039 Likes on 805 Posts
Sounds like money to me.
Old 07-16-2018, 03:35 PM
corvettedave383
what was your outcome then??
Old 07-16-2018, 03:39 PM
sstonebreaker
sstonebreaker's Avatar
Had a sound just like that and it turned out to be a bad lifter that shattered and ended up completely destroying my engine.
Old 07-16-2018, 04:04 PM
MelWff
MelWff's Avatar
Received 1,807 Likes on 1,598 Posts
use a stethoscope or rubber hose to try and isolate the source of the noise. I had a hard to chase knock once and the return spring on the mechanical fuel pump arm had broken causing the arm to make the noise.
Old 07-16-2018, 04:17 PM
C3 Stroker
C3 Stroker's Avatar
After removing the heads, I found it was detonation damage (pistons and heads) to the #2, #8, and #3,#5 cyls. #5 had part of the piston broken off. I was surprised the engine was running at all. Like I said, it sounded exactly like yours.
Old 07-16-2018, 04:57 PM
v2racing
v2racing's Avatar
I wouldn't run it anymore. The more you run it, the less parts you'll be able to reuse. Start tearing it down. It's not going to heal itself. As suggested, start at the top and work down until you find it.
Mike
73racevette (07-16-2018)
Old 07-16-2018, 06:10 PM
corvettedave383
thanks guiys, will start at top and work my way in, got a boroscope coming tomorrow , so will have a look in at the valves and pistons via sparkplug hole
Old 07-16-2018, 06:26 PM
derekderek
derekderek's Avatar
Received 3,387 Likes on 2,632 Posts
Grab a piece of heater hose. Makes a good stethoscope. THEN run it along the oil pan. This is an easy car to drop the pan. It is a rod. If brave enough to mess with rod bearings, get the size off the bad ones and post it.
Old 07-16-2018, 06:29 PM
corvettedave383
ok cheers
Old 07-16-2018, 06:58 PM
Cavu2u
Cavu2u's Avatar
Mike
Take Mike's advice.
I would first drain the oil and pull the pan. Look at the crank assembly and inspect what's visible there. Oil analysis is a good thing for identifying failed components, but if there's a lot of Metallica present in it, just save the money you'd spend the analysis and spend it on the rebuild/replacement.
Good luck.
Just curious: What's the engine's history?
Steve
Old 07-16-2018, 11:30 PM
427Hotrod
427Hotrod's Avatar
Received 1,874 Likes on 912 Posts
2017 C2 of Year Finalist
What's oil pressure look like??
JIM
Old 07-17-2018, 02:50 AM
corvettedave383
Originally Posted by Cavu2u
Take Mike's advice.
Good luck.
Steve
its about 6 years old, but has only done about 2000 miles, it is a custom built sbc 383, mid 70's block and all brand parts inside, all forged, designed for forced induction
Old 07-17-2018, 02:51 AM
corvettedave383
JIM
iam getting great oil pressure, just cranking over it gets great oil pressure and loads when started
Old 07-17-2018, 05:42 AM
bjankuski
bjankuski's Avatar
Sounds like valve train to me.
Old 07-17-2018, 06:35 AM
cooper9811
cooper9811's Avatar
Had a very similar sound on my 406 a few years ago - a roller rocker arm trunnion clip broke and the rocker arm was loose - made an awful clacking sound.
I pulled the pan and found the clip in 3 pieces.I tore the engine down, and unfortunately found some pretty bad scratches in the cylinder walls. I considered cleaning and running it - I probably could have - but instead chose to replace the block (it was an old junkyard block anyway. It was also an excuse to upgrade).
To Engine not happy!
Old 07-19-2018, 01:13 PM
corvettedave383
Update - so i removed the shaft rocker from low compression cylinder, with the rocker on, it produces 120 psi, all others are 140+, with the rocker rermoved, ie valves fully closed when turning engine over, it only managed to produce about 70 psi and then after another few trys at turning over engine, ended up down at 10 psi, so what does that mean?? bent valve or ?? - there is alot of oily burnt crusts on the pistons, which is more than likely on the valves aswell, seen on my boroscope today
Old 07-19-2018, 01:41 PM
Danish Shark
Danish Shark's Avatar
Maybe it's just the picture, but it looks like the valve stem has started mushrooming?. Maybe the rocker was pounding on the valve due to being too loose?
Also the sweep pattern looks quite wide?
Old 07-19-2018, 05:02 PM
corvettedave383
i will have a closer look at that, thanks
Quick Reply: Engine not happy!
