Recommendations for C-5 splash guards
I want to install splash guards on my 2003 to help prevent stone chips.
I do not want to drill any additional holes in the wheel wells, just use the existing fasteners locations.
Not sure if I want black or body color (50th anniversary red).
Any thoughts or advice on a set of 4 which will work?.
Thanks
Thanks
Thanks
Thanks
They also sell extra spring clips
jrd1990zr1 (07-19-2018)
Received 2,706 Likes
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'-'17-‘18-'19-'20-'21-'22-
'23-'24
These are much more expensive than the ones mentioned but they are better. They will also paint to factory color
https://www.ebay.com/itm/97-04-Altec-C5-Corvette-Painted-Front-Rear-Splash-Guards-Mud-Flaps-Set-of-4/171155581967?ssPageName=STRK%3AMEBIDX%3A IT&_trksid=p2060353.m1438.l2649
These are discreet virtually disappearing on a black car. I take them off when detailing and my only issue are the rear spring clips which can scratch paint finish. However, this is probably my poor install and removal technique. Any tips on my spring clip issue?
https://www.rpidesigns.com/shop/item.aspx?itemid=1949
These might be the same. I like them. Easy to install and you don't notice them unless you are looking for them,
They certainly appear to be the same as MAM's
Received 19,286 Likes
'20-'21-'22-'23-'24
You do not want to paint them body color, as they will stick out like a sore thumb. When black, they will blend in with the tires.
Unless you live in the country, or drive on dirt roads all the time, do you really need them? I don’t have them, and I’m sure my wheels/ tires are larger/ wider than yours with no issues. 3M is your friend!
To me, ‘splash guards’ don’t belong on a sports/ performance car. No one has ever said to me, like your car, but you could make it so much better with some ‘splash guards’...and of course some Caliper Covers.
frank
frank
Thanks
Thanks
frank
frank
Despite what some may think, splash guards have no effect on the drivability or fun factor in owning a sports car.
The following 3 users liked this post by JR-01:
The only ones I've seen that are truly integrated looking, are the C6Z factory splash guards. They take some work to shape them, but are actually attractive.
The following 2 users liked this post by zeevette:
FYRARMS (07-18-2018),
How about some pics of the Mid America set on your car. It does state "some drilling required" ?
Thanks much!
Thanks much!
I disagree with Jetz. My rpidesigns are painted silver with Duplicolor vinyl paint and they are an exact match to the car and are unnoticeable until you look for them, blending right in with the body.
frank
frank
I understand what you are saying, the splash guards are a temporary protection, not an appearance item.
Thanks for your thoughts, John
