Meth tank empties on startup
Like the title says. I have an alky meth injection kit and sometimes when I start the engine the system floods with methanol. As far as I know the pump isnt kicking on causing it because tonight i turned off the controller and it did it a little bit. You can shut off the engine and it will stop.
red light on the control says on when I turn the ignition on. The indicator led stays off until moderate throttle and then turns green at 5 psi.
still very frustrating. Anyone have any ideas?
Are you wired to the map sensor and if so is it still the stock sensor or a 2/3 bar sensor? If I remember correctly the stock sensor will cause the pump to constantly run when the system is powered on.
It's actually running off the output from an AEM boost gauge. It reads out to 35psi, so I would assume it's a 3 or 3.5 bar sensor. I wasn't quite sure how to tap into my 2 bar map sensor that I have installed on the car, and this was really easy to tap into.
How exactly do you have all this stuff wired together? Previously you stated that you had it wired "supply power, ground, signal" but that is not how to wire an AlkyControl kit. The 3 wires coming from the pump go to the PAC controller and then the PAC has two wires that go to the MAP sensor, two wires that go to the turn on LED and two larger gauge wires that provide power and ground to the PAC. Also, the MAP sensor used by the alky control kit uses a 5V reference, this may or may not be a part of your issue.
Is the nozzle lower than the reservoir? Talking to Bret, I learned that the engine can siphon the meth without a check valve if the nozzle is lower than the reservoir. Just a thought...
Supporting Vendor
If you want to try a little test, start with a full methanol tank. I would run the car some to make sure methanol is flowing and then park the car as you normally do. Without turning the key on, remove your lower charge pipe and be prepared to have methanol flowing out (wear appropriate PPE).
Keep in mind that with the charge pipe off, you may need to put the car back on level ground before it begins to flow out. If it in-fact does this, I would get a methanol-compatible check valve installed immediately. It needs to be on the output side of the pump as opposed to the inlet side because it's going to take some pressure to overcome whatever spring is inside the valve. If you already have a known working check valve in the system, you most likely need to adjust the system to come on at a higher input voltage. When the AEM controllers begin, they start out turning the pump very slowly with a PWM signal. It'll be virtually impossible to hear it running at this level with the engine running. If you want to prove this is the issue, remove either your nozzle or your entire charge pipe, start the engine and observe.
Bret
Bret
Received 1,762 Likes
Plus IF IT doesn't have a good ground it will do the same thing, will pump the tank empty, ask me how I know that it happen with me on the c7 set up. Got a good ground work great then... But also had to chg out plugs and also the intercooler pump a ton into the intercooler...Robert
so you had a bad ground on your install. Did it cause your pump to go on as soon as
you start the car and it went empty? I also have a c7 with alky meth kit. I turn the car on the led light is solid red and it sprays out all the methanol
Supporting Vendor
If you lose the ground reference on the MAP sensor circuit for the Alky system, it will pull the MAP signal high and think you're at max boost and begin pumping at maximum speed.
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
