where are the AC high and low pressure relays for a 1986 Corvette air conditioner?
Old 07-17-2018, 02:01 AM
00JIMO00
8th Gear
00JIMO00's Avatar
Default where are the AC high and low pressure relays for a 1986 Corvette air conditioner?
Where are the high and low pressure cut out switches for 1986 corvette ac located?
Old 07-17-2018, 02:14 AM
Hot Rod Roy
Hot Rod Roy's Avatar
Originally Posted by 00JIMO00
Where are the AC high and low pressure relays for a 1986 Corvette air conditioner?
What's behind this question? What makes you think there are high and low pressure relays in the system? (There aren't) Or are you asking where the high and low pressure switches are located? Or are you asking where the high and low charging ports are located?
You obviously need the Factory Service Manuals (FSM) for your car. (Don't bother with the Chiltons or Haynes joke books.)
00JIMO00 (07-17-2018)
Old 07-17-2018, 02:29 AM
00JIMO00
8th Gear
00JIMO00's Avatar
Old 07-17-2018, 04:35 AM
Joe C
Joe C's Avatar
cycling switch compressor - a.k.a. low pressure cycling switch --
hope this helps...
Old 07-20-2018, 01:52 AM
00JIMO00
8th Gear
00JIMO00's Avatar
hope this helps...
Thanks,
Old 07-20-2018, 01:53 AM
00JIMO00
8th Gear
00JIMO00's Avatar
Thanks
To where are the AC high and low pressure relays for a 1986 Corvette air conditioner?
Quick Reply: where are the AC high and low pressure relays for a 1986 Corvette air conditioner?
