does the column need to be from a 93 specifically? i have one from a 94 automatic maroon and one from a 96 black 6-speed.
I don't know if the 94 will work or not will check it out .. But has to be tight in the tilt deal not hard to check out if in the Vett just grab the wheel and see if any play back and forth if out of the vet just grab it like your trying to brake it in half you can fell and see it moving .. Has to be the auto one .. you check for tightness I 'll check fit .. Thanks
mike, i checked the tightness of the column, one of the things i can do right now, and it has play in it. it won't break apart but still has play.
sorry
rich
sorry
rich
Thanks anyway , I think they all have some play in them ,people pulling on the wheel getting in and out on the thing and after awhile play .. I guess I'll rebuild mine ,let me see spring A goes in to what .. How hard could it be . Right ???
