Rear trailing arm thingys? What are they?
What do these little plates do?
I see in some diagrams there is supposed to be a cotter pin through them? But the holes are WAY too big for that.
Is there supposed to be something in there?
Duckstu (07-18-2018)
Received 3,135 Likes
What year is your car?
The alignment shims have a long cotter pin that goes through the frame piece there and just holds them in, the holes in the shim are large.
Maybe it's just the angle but those shims look like they are sticking out an awful lot
Here's a set off a 72, you can see the head of the cotter pin in the lower /right corner of the image above the time stamp
The shims don't really stick out of that pocket
Maybe your's are different
M
M
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
As mentioned above, these are the trailing arms shims https://willcoxcorvette.com/corvette...-63-82-230-057
It appears you have a gap in between your shims. If so you should check there is no play in the arm. If they are rust corroded you have to closely check the arm for rot- they rot from the inside out. Look at Mooser's picture you can see the shim are tight between the frame pocket and arm bushing. If they are loose or missing the car will steer from the rear, if the arm is rotted it will bend and break under load.
Ok thanks.
I can't wiggle them with my fingers,.... but the one closest to the outside of each control arm is definitely touching the arms.
But I don't see any scraping of the paint,.. so I know they aren't moving relative to the arms.
Still,.. I think I'm going to take it to the local Vette restoration place to have a few jobs done,.. and looking at this will be one of them.
funny this is coming up tonight im in the middle of taking mine out too and before I took my drivers side out the shims looked the same as his and I could move it in and out from the car about 4-5 inches .
I knew both sides were done before i started I could move the wheels up and down about the same 3-4 inches on the passenger side and 4-5 on the drivers .
I got really lucky and the bolts came right out no sawzall needed every bushing is dry rotted and cracked
Ok thanks.
*****Still,.. I think I'm going to take it to the local Vette restoration place to have a few jobs done,.. and looking at this will be one of them.
I’m always on the lookout for a reputable and trusted shop. Do you mind if I ask what restoration shop you’re thinking of using?
There's a couple shops in my area with good to great reps (according to some owners of MINTY late 60's early 70's Vettes in the area.)
One is Meisterworks, another is Vettestorations,.. and the third is Drayton Motors.
I'm not having a big resto done,.. just needing 3-4 things fixed. I'll probably take it to Drayton Motors.
May have the rear arms rebuilt with new wheel bearings, bushings (though I think they were done already), rebuild the parking brakes, check the front suspension, fix a small trans leak, re-do the headlight mechanisms (the adjusters are frozen),.. but I have the linkages, headlight adjustment sockets and screws en-route,.. so I may have those fixed this weekend.
But this morning it's going to a body shop to be cut & buffed. I got up early this morning to remove the rear bumpers, hood grills and chrome fender louvers.
Jstan2014 (07-18-2018)
