C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
LS9 idle fuel pressure
Old 07-19-2018, 02:23 AM
LeForce
LeForce's Avatar
Default LS9 idle fuel pressure
I'm using an LS9 in an engine swap project, I'm also using an adjustable fuel pressure regulator. Can someone tell me what's the stock idle fuel pressure for the LS9? (with vacuum hose connected or not)?
I recall that the stock pressure for the LS3 is around 60psi but I suspect that the LS9 needs higher pressure since it's supercharged.
Thanks
Old 07-19-2018, 07:06 AM
redbird555
redbird555's Avatar
It’s not as simple as normal ls motors of 58psi...ls9 fuel pressure sits right around 35-37psi at idle and cruise then when WOT and high boost demands enter fuel pressure bumps to 87psi
Old 07-19-2018, 08:31 AM
LeForce
LeForce's Avatar
Any tips how to set the fuel pressure?
Old 07-19-2018, 11:38 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Set it with a base pressure high enough to support what you need to do, and tune around it. You won't have the same functionality as a stock zr1, but you can tune around it and just have to adjust everything in the ecu to accommodate since you can't run the factory PWM controlled pump setup. .
Old 07-19-2018, 11:59 AM
LeForce
LeForce's Avatar
I was hoping to run the engine on the stock tune & not have to tune it, is there away to mimic the factory PWM control? I'll set the pressure to 37psi for the break-in duration.
Old 07-19-2018, 12:01 PM
Unreal
Unreal's Avatar
37psi is strickly for idle and low load, and once you give it any gas it will go super lean.
You can try to rig up a whole zr1 fuel pump assembly/etc, but that would cost WAY WAY WAY WAY more than just having someone tune it.
Old 07-19-2018, 12:49 PM
LeForce
LeForce's Avatar
Well 37psi would be just for the break-in duration as the engine is brand new. The fuel pressure regulator is vacuum referenced, I have set it first to 43psi at idle & I tried a couple of minimal revs & I noticed that fuel pressure would almost instantly climb to 80s psi. I will check the AFR to evaluate whether it requires a tune. Are you familiar with the stock target AFR, mid to high range RPM?
Old 07-19-2018, 12:56 PM
lt1z
lt1z's Avatar
You need to tune it when the LS9 is not in a ZR1. What I would do is set base PSI to 58 and boost reference the regulator to raise pressure 1:1. So if seeing 11 psi it will raise to 69 psi under full boost. That will be enough. If you have a crate LS9 controller it will work similar, but a factory ZR1 tune assumes a FPCM that ramps to 6 bar.
Old 07-19-2018, 01:15 PM
LeForce
LeForce's Avatar
I'm reading the engine manual, it says "ensure that fuel pressure is capable of 600 kPa (87psi) with the engine running, the pressure regulator must be vacuum referenced" It looks that my regulator would easily achieve 6 bar at high RPM. I don't have a GM tuner anywhere around here, I'm a tuner myself but I never did a GM engine, only Japanese engines. I should be able to fine tune the fuel table myself if I have to, but I need to know what are the stock AFR targets on the LS9.
Old 07-19-2018, 01:28 PM
Unreal
Unreal's Avatar
Just look at the maps. ~14.1:1 at part/idle, and look at the PE table, which varies from ~10.5-12:1 or so depending on loads/rpm/etc.
Old 07-19-2018, 01:34 PM
LeForce
LeForce's Avatar
I tried 60psi as idle pressure & the engine ran very rich with black smoke when revved, base pressure definitely needs to be lower.
Old 07-19-2018, 01:41 PM
LeForce
LeForce's Avatar
I haven't opened the maps yet, I just received my Hp tuners suite, are fuel table numbers represented in actual AFR figures? That sounds good! With other ECMs the numbers are simply fuel injector duty cycle percentages.
Old 07-19-2018, 01:59 PM
Unreal
Unreal's Avatar
No, they are typically EQ ratios based of the stoich value programmed in.
Old 07-19-2018, 02:01 PM
NicD
NicD's Avatar
OK so LS9 in a swap application, what controller are you using? That will change everything...
Old 07-19-2018, 02:18 PM
lt1z
lt1z's Avatar
If you are using an OS from a ZR1 then I would expect that without tuning. The LS9 crate engine controller is different because it is not expecting FPCM control of a brushless pump.
The crate controller specifies base pressure with a boost reference and specs for mounting the MAF. Their tuning will run the car with those settings but it is on the rich side and would still definitely benefit from tuning. What fuel pump line an regulator setup is being used? Is the MAF mounted as described in the directions in the correct size and length pipe? 02 sensors installed yo allow closed loop operation with a full length exhaust?
Old 07-19-2018, 02:21 PM
LeForce
LeForce's Avatar
Thank you for the question, I purchased what's called the LS9 connect & cruise package from GM Performance the kit included the engine, T56 super magnum gearbox, and LS9 controller kit (ECM & harness) GM part # 19354338
https://www.chevrolet.com/content/da...m-19354338.pdf
Old 07-19-2018, 02:36 PM
NicD
NicD's Avatar
Crap I can't remember what the GMPP LS9 tune shows in the injector flow rate table but looking at the guide it says the regulator must be set for 60 psi at idle and then 65 psi at WOT but that isn't a 1:1 boost reference so that's kind of odd. The guide also says the regulator must be referenced so that needs to happen. Either way I would be tuning it afterwards since there are so many variables in a swap application and the MAF tube orientation, filter, etc will all change the calibration.
Old 07-19-2018, 07:02 PM
LeForce
LeForce's Avatar
Yes MAF & O2 sensors were installed according to the manual, closed loop seems to work fine as idle is very stable regardless of fuel pressure. I'm using an Aeromotive A1000 inline fuel pump and an Aeromotive fuel pressure regulator. Again, I'll adjust the fuel table if I have to, but first I want to achieve acceptable & safe AFR through a suitable fuel pressure & then I might only fine tune it through the fuel table. I still don't have a definite answer regarding the stock AFR targets, @Unreal mentioned that such figures would be found inside the tune file. Instinctively, I'd shoot for something like 12.5 during spool up, 11.5 at mid range, dropping to 11 by red line.
I really appreciate your feedback, please keep it coming
Old 07-25-2018, 03:25 PM
LeForce
LeForce's Avatar
After going through the manual, I'm positive that controller I have is meant for the LS9 as a swap engine not a ZR1 controller. So it's meant to work with a vacuum referenced pressure regulator, not a PWM controlled pump. The manual says that idle pressureI should be at 60PSI, but the complete sentence describing fuel pressure in the manual is a bit tricky, "The required fuel system needs to be controlled to 60psi at idle and 75 GPH @ 65psi for WOT conditions" I don't believe that pressure would be at 65psi only during WOT! I think the sentence is simply explaining what should be the fuel flow at a certain pressure. In a different section in the manual, it says "ensure the fuel pressure i capable of 87psi with the engine running" and "ensure the fuel pump has the following flow capacity, minimum 75 gph @ 65psi. I believe that fuel flow should fine & work well with the controller if I set idle pressure at 60psi then the vacuum controlled regulator would simply increase fuel pressure as air pressure changes. I'll keep an eye on AFR to make sure that the engine isn't running too rich or too lean.
I appreciate your feedback
To LS9 idle fuel pressure
Quick Reply: LS9 idle fuel pressure
