New Member Harmonic Balancer Death Wobble Replacement Parts
First off, the people on this forum have been great so far, very helpful!
I recently purchased a 02 coupe 6spd with 75K and am experiencing severe harmonic balancer death wobble, coupled with the noise that goes along with it. I've been researching replacements but am still getting mixed reviews. Can people chime in and give advice on what they think I should replace with? Also, If anyone can provide the total parts list of what I need so I can just bring the supplied parts to the mechanic, that would be greatly appreciated!. I am leaning towards ATI for a one and done application, but for the price is it overkill? Also, what other items do you guys recommend, since the steering rack will be out? I was thinking water pump, anything with the rack? anything else I am missing?
Thank you
Thank you
I am leaning toward the ATI, with APR bolt. No big power goals other than headers, X-pipe, axel back. But your comment about the cam has peaked my interest.....decisions, decisions. What cam would you suggest for street-ability?
Depends. If you're doing the work yourself an OE Balancer will probably last 5-7 years or more before you have to revisit it and can be had fairly inexpensively. But, even the new ones have a slight wobble. ATI is a great balancer. A lot more money and a little more work. But we install pinned ATI dampers with all of our supercharger builds and if a customer has any performance mod aspirations we recommend it so that the supercharger option is open in the future. If it were my car and I knew I was never going to put a blower on it. I'd go back with OE. If I thought there was a chance I'd mod it or if I drove a ton of miles I'd put an ATI on it. Get a new bolt. OE or ARP. OE has sealant on it that I like and I'm used to them but the ARP is fine as well you just have to add your own silicone sealant. If you are doing it yourself invest in the flywheel holding tool. Lots of vendors for those out there now so no reason to try and work around it.
In your earlier thread you mentioned that you had a dealer inspect the car prior to your purchase. If you do actually have a balancer that is badly wobbling and it was NOT reported to you, it says VOLUMES about the Stealership you went to. I think MOST on this Forum would advise you to find a shop that specializes in Vettes. Check them out with local Vette owners, preferrably with owners that have C5's and newer. The C5 was GM's first entry into an all electronic Vette and that alone means you need knowledge of the issues the C5 has. DEFINITELY stay away from a Stealership. Most of the Tech's they tend to employ have never seen a C5 let alone be knowledgeable of their quirks. JMHO
Thanks Russell, what about the powerbond HB?? better than GM, but less than ATI?
well, I didn't want to start a snowball here, haha. But if you plan on headers and such, you should get a tune also. So if your getting a tune you mine as well get a cam. Snowball starts. Anyways, you could just get a nice upgrade like a 224 or something. Not too crazy but pickup 25 or 30 horsepowers.
I don't particularly care for Dayco the parent company of Powerbond. Just personal anecdotal experience, your mileage may vary. And my normal practice is OE or the best the aftermarket has to offer. I don't typically deal in the in between or budget stuff. Some people like them I don't have much experience with them to give an educated opinion.
Can anybody provide a FULL list of all parts needed for a balancer replacement? I did mine a while ago. If i remember, it was a...
balancer itself, crank seal, Loctite blue, belts (x2 --serpentine belt and accessory belt?), ARP bolt...and aren't there 1 or 2 other miscellaneous parts needed for the balancer replacement?
There are alot of post's on the Forum about the OEM junk. Most ppl use the Powerbond PB1117N (stock size) and the ARP bolt 234-2503 and a new GM front seal
Banned Scam/Spammer
Location: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Received 3,916 Likes
There are a couple other "while you're in there items" you should do:
Steering rack bushings, and front crankshaft seal (cheap). Also possibly the front balljoint boots and motor mounts after assessing their condition.
I know a lot of people hate on the OEM. I install them for a living and here is my observation. When an OEM part lasts 100k miles "it is junk" when an aftermarket part lasts 50k miles "that's as good as you could ask for". There's definitely a double standard in my observations. Most of the OEM balancer failures are happening at around 60-70k miles and a lot of years. Many make it beyond that. But time plays a role. Rubber and adhesives have a working life and nothing lasts forever. In this case the OEM provided 16 yrs and 75k miles. Hardly worthy of being described as junk. And the OE powertrain warranty was 3yr/36k miles three times the Dayco warranty and less than half as long as the part actually lasted. I don't doubt the powerbond pulley. I don't have enough data to recommend it. We've seen ATIs hold up to supercharger build where others have failed so we prefer those in that application. We have a lot of evidence to support OEM balancers going at least 10 years and 60k miles. We don't have the same body of evidence for the Powerbond although there is a lot of anecdotal evidence supporting it as a quality product. I think any of the three is a good choice. Just wanted to offer my defense of the OE part that while not being top notch is certainly not worthy of the derision it gets. You can't expect a component that has rubber and adhesive as part of its construction to last indefinitely in that environment.
Read this thread about using a new OEM part, post #6 has all the info in it
https://www.corvetteforum.com/forums...it-or-not.html
One more data point.
I have a 2004 Corvette C5 with 171,000 miles on it. It is a daily driver. It still has the original harmonic balancer on it. I've marked it, looking for slippage and checked it for wobble. None so far.
That said, I bought another OEM harmonic balancer as I was expecting trouble (from reading the forum posts). I think I got my money's worth on the original....
Below is a quote taken from Kurt Urban, who is a wealth of technical knowledge and historical information on the LS1 and its development and racing. Take from it what you will, but I used the ATI when I replaced mine. The ATI can also be rebuilt. You send just the dampener section back to ATI and they will rebuild and return. So the ATI should be a lifetime installation. Note that because the ATI is in pieces, you don't have to "pull" it to remove the dampener, it simply unbolts from the hub.
"We did test all the popular dampers then (2001) and the ATI was best followed by the stock one if your rpm was under 7000."
Careful if you are going to do the water pump!!!
There were 2 variations of the water pump used on the C5. The original version has a completely different T'stat cover and T'stat than the later version. The two parts are NOT interchangeable. You need to first figure out which pump the car has and then determine which pump you will be getting. If you go rebuilt then there is a 50/50 chance of getting either. If you go NEW then it is highly unlikely you will get the older style as they haven't been produced since about 2004. Read the following for more info on the issues at hand:
https://www.corvetteforum.com/forums...t-opening.html
https://www.corvetteforum.com/forums...d-subject.html
As my post indicates, you need to check FIRST. The threads I linked show the old and new style pump T'stat cover and T'stat. Easy to identify what is on your car from the pictures. Also in the links are info on the T'stat opening both old and new style. When you purchase the replacement pump you will be able to determine what the new pump is.
For new pump (ie NOT a re-manufactured pump) it WILL BE the new style pump body that requires the new style T'stat and new T'stat cover. If your car already has the new style T'stat cover then you are all set. If your car has the old style T'stat cover then you need to order a NEW style T'stat cover and NEW Style T'stat. The old parts will NOT SEAL if you try to mix them with the new style pump.
If you order a re-manufactured pump it is a crap shoot as to whether you will get the old style or new style pump body since there are tens of thousand old style cores in the system that can be re-manufactured. Measure the diameter of the opening for the T'stat on the pump body of the re-manufactured pump. The diameter for the OLD style will be 2". The diameter for the NEW style will be 1 7/8" (actually 1.86" if using a vernier caliper.) Simple rule to follow from that point on. OLD style body needs OLD style cover and T'stat, NEW style body needs NEW style cover and T'stat.
Thank you GM for creating this mess................
