electrical fault
Old 07-20-2018, 09:11 AM
sercorvette
4th Gear
sercorvette's Avatar
Default electrical fault
I own a corvette c5 2002 which presents me with a general failure of the electrical system, radio does not work, air conditioning, do not lower the windows, does not clean the windshield etc, which can be the fault? Can someone help me?
Old 07-20-2018, 09:41 AM
JR-01
JR-01's Avatar
Received 1,063 Likes on 805 Posts
Did it all just stop working or did something happen?
Old 07-20-2018, 11:30 AM
photonhunter
photonhunter's Avatar
What voltage does your battery show as measured with a meter at the battery terminals?
dan k.
Old 07-20-2018, 12:02 PM
aj98
aj98's Avatar
With no power, you have to start at the battery.
I have a similar issue with 2 different cars over the last couple months.
My C5 had intermittent compete loss of electrical power.
After going through worst case scenarios (and the resultant stress) in my head, turned out to be a simple (and cheap) fix
Check for loose, stripped, and or corroded terminals.
I found the threads on the terminal post were stripped, which caused a loose fit, and intermittent no power.
Replaced the posts, wirebrushed both cables, no more problem.
GFs spare car had been sitting for some time - no power, wouldn't even turn over with jumper cables.
Ok, maye the battery is completely flat - let her car and the jump car stay connected for 1/2 hour. still no joy -
meter read zero, even with the jump cables still connected
When I unscrewed the terminals to pull the battery, discovered heavy corrosion on the base of the terminal.
Retest battery without the terminals screwed in - meter said 14v.
Screw the terminals back in, 0 volts on the meter.
Replaced the terminals (2.50$/pair at advance auto).
Started right up.
sercorvette (11-13-2018)
Old 07-20-2018, 06:29 PM
Support Corvetteforum!
Received 19,188 Likes on 13,911 Posts
'20-'21-'22-'23-'24
Moved to C5 Tech.
Old 07-21-2018, 08:46 AM
JBB
JBB's Avatar
Check in the stickys. (top of section) I wonder if corrosion at G-101 could be your problem. It's a multi wire ground @ top of frame below the upper radiator hose. ( Black plastic )
To electrical fault
Quick Reply: electrical fault
