Front crank seal leaking
Old 07-20-2018, 11:31 AM
turbobuick33
turbobuick33's Avatar
Default Front crank seal leaking
On my 96 LT4, I noticed light oil on the bottom of the front oil pan and the crank sensor connector is covered with oil. Looks like the crank seal has a small leak. There are no oil drips on the ground. Should I replace the seal now or wait till it gets worse, like when it starts dripping on the floor?
Old 07-20-2018, 01:37 PM
mtwoolford
mtwoolford's Avatar
Remember that timing chain cover has three seals; do them all at once.
Old 07-20-2018, 04:28 PM
Whaleman
Whaleman's Avatar
Can also be the crank sensor o-ring.
Old 07-21-2018, 05:57 AM
turbobuick33
It could be the crank sensor o-ring. The opti-spark and water pump was replaced a few thousand miles ago. I assume the timing cover seals were replaced but not sure.
Old 07-21-2018, 07:37 AM
PatternDayTrader
PatternDayTrader's Avatar
Received 1,056 Likes on 769 Posts
That barely even qualifies as a leak.
Clean it off with brakeclean and then reinspect it at the next oil change.
To Front crank seal leaking
Quick Reply: Front crank seal leaking
