FS: AXDSP-MOST1 C7 GM Vehicle interface
Currently the only item on the market that allows you plug and play DSP for your C7 and other GM vehicles.
Ordered 2, one for my C7 ZO6 and one for my wife's Escalade, only need one.
Brand new not used.
$390 shipped
General Features:
- Plug & Play Installation
- AX-DSP Included
- Designed for Select 2014-Up GM Vehicles
- Includes an Amplifier Bypass Harness
- Retains Factory Chimes
- Retains Factory Parking Sensor Chimes
- Retains Onstar Voice Prompts
- Adjustable Chime Level
- Micro 'B' USB Updatable
- 31 Band Graphic EQ
- Clipping Detection and Limiting Circuits
- Converts Fixed Level Audio Output to Analog Output
- Control All Features & Adjustments with the Axxess DSP App
Compatible Systems:
- Axxess AX-DSP
Compatible Models
- Buick
- 2017 - 2018 Encore
- 2018 - 2018 Enclave
- 2016 - 2018 Envision
- 2014 - 2018 Lacrosse
- 2014 - 2018 Regal
- Chevrolet
- 2016 - 2018 Camaro
- 2014 - 2018 Cheyenne
- 2015 - 2018 Colorado
- 2014 - 2018 Corvette
- 2016 - 2018 Cruze
- 2018 - 2018 Equinox
- 2014 - 2018 Impala
- 2016 - 2018 Malibu
- 2015 - 2018 Suburban
- 2014 - 2018 Silverado
- 2018 - 2018 Traverse
- 2015 - 2018 Tahoe
- 2016 - 2018 Volt
- GMC
- 2017 - 2018 Acadia
- 2015 - 2018 Canyon
- 2014 - 2018 Sierra
- 2018 - 2018 Terrain
- 2015 - 2018 Yukon
- Cadillac
- 2015 - 2018 Escalade
- 2016 - 2018 CT6
- 2014 - 2018 CTS
- 2017 - 2018 XT5
- 2013 - 2017 XTS
- 2013 - 2016 SRX
Interface Contents:
- AX-DSP
- AX-DSP-MOST1 Interface
- AX-DSP-MOST1 Harness
- AX-DSP Harness (16-pin, 20-pin)
FYI - this includes a DSP. If you have your own favorite DSP this may not be the right product.
There are 2-3 products that allow access to "un Bosed" sound in the C7.
AXDSP-MOST1 - Has a built in DSP. If you're looking for a product with a built in DSP this is a good product. If you want something that allows you to use a different DSP or additional DSP features (autotune, etc) this may not be what you want. The design doesn't allow you to skip the DSP, so you would have to set the DSP to flat and then feed the output to the DSP you want to use. This will result in increased noise. ~$430
NAVTV M650-GM - Has a analog and digital outputs for your DSP. ~$850. Nav TV M650-GM
Pac Audio AmpPro AP4-GM61 - similar to the NAVTV M650-GM but the digital output is optional. Not yet available. Rumor was it would be available the end of June 2018. ~$350. Sales pdf
Still available. Plug and play for your C7.
Year(s)MakeModelTrim LevelAdditional Info2015-2018CADILLACESCALADEALL TRIM LEVELS—2016-2018CHEVROLETCAMAROALL TRIM LEVELS—2015-2018CHEVROLETCOLORADOALL TRIM LEVELS—2018CHEVROLETEQUINOXALL TRIM LEVELS—2014-2018CHEVROLETSILVERADOALL TRIM LEVELS—2015-2019CHEVROLETSILVERADO HDALL TRIM LEVELS—2015-2018CHEVROLETSUBURBANALL TRIM LEVELS—2015-2018CHEVROLETTAHOEALL TRIM LEVELS—2018CHEVROLETTRAVERSEALL TRIM LEVELS—2018GMCACADIAALL TRIM LEVELS—2015-2018GMCCANYONALL TRIM LEVELS—2014-2018GMCSIERRAALL TRIM LEVELS—2015-2019GMCSIERRA HDALL TRIM LEVELS—2018GMCTERRAINALL TRIM LEVELS—2015-2018GMCYUKONALL TRIM LEVELS—2015-2018GMCYUKON XLALL TRIM LEVELS—
