Mamo ECS build
Mamo ECS build
Hello all,
Been lurking in the forum for a couple of years now since buying my 07 Z. A lot of great information on here that's helped me decide on how to go forward. My car is at my buddies shop getting some goodies installed as I type this. Car has a mild cam, AR 1 7/8 headers and Corsa exhaust from when I bought it. Dyno'd 495hp when I got it. Only has 10K miles on (6K from me in the last year or so). Decided to get the heads done, which turned into why not upgrade, well while I'm doing that... you know the story. I haven't seen anyone run boost through a Mamo set up yet, at least that I've seen. I had Tony keep the heads at 70cc to shoot for a stockish compression knowing I would likely add boost. Was planning on seeing what it put down all motor first but with ECS posting about a moving sale decided to pull the trigger now. Going to break in the clutch and rear then add the supercharger and get tuned. Mods will be as follows:
-Mamo TFS heads
-Mamo MSD
-NW102 TB (modified for boost)
-mantic twin
-DSS carbon fiber DS
-3.90 Motive gears (hate how tall these cars are geared)
-ECS 1500 3.6 pulley with 10% OD balancer (leaving restrictor in)
- ECS stage one E85 fuel system with ID1050X injectors
- Alky meth kit
-DSX flex fuel sensor
Im sure I'm forgetting something in there. I know most wouldn't spend the money on these type of heads if they are going boost but I'm a big believer in do it once and do it right. I think with the reduced restrictions in he heads/intake the advantage that I''m going to have over stock stuff is the power under the curve. I'll be interested to see what it puts down. I'm also at altitude so I have a bit more latitude on power before I start breaking stuff, 6000+ ft really reduces the actual hp/stress on things. Anyone run boost through Tony's setup yet?
-Mamo TFS heads
-Mamo MSD
-mantic twin
- Alky meth kit
Not a fan, and seems money could have gone to much better places. MSD intakes have enough trouble staying together NA let alone with boost. Best of luck, but seems like a ton of money that could have been spent elsewhere, since you are going to hit octane or motor limit.
Should be interesting, just seems like money used for the fancy heads/intake/TB could have built a bottom end, or gone into wheels/tires/suspension/etc etc.
I'm selling my DSS CF Shaft, if you haven't grabbed one yet. Just need to pull it out of the car.
I understand the stock heads are good from the factory and can be cleaned up to be even better. I also understand that everyone's going to have their own opinion. I generally keep pushing the limit of my cars until they break and then build them stronger. What I don't generally subscribe to is the theory that since you will be adding boost the other components are a waste. If a head can flow the best NA then boosted the results can generally be compounded, not negated. I'm sure I'm pushing the limit of the stock bottom end, which is why I'm going to leave the restrictor in for now. When I'm ready to build the bottom end I'll take it out and push it a bit further.
I also go against the normal belief that gears make a car harder to launch or control, people have been running high HP cars for decades with much steeper gears. Everyone told me I wasn't going to do anything but spin in my 03 cobra when I put 4.30's in it. I run 19lbs of boost in a 4100lb vert and with the IRS cut low 1.6 60' times on 3 year old 18" DR. Torque is going to take the path of least resistance, if you are loading up a tire because you can't get them rotating fast enough they will break free, make it easier for the engine to match tire RPM and you can actually move out faster.
As as for this car, I also have Gforce axles going in, ECS trans brace, 17x11 with 325 Hoosiers and already installed Viking double adjustable shocks . Also have 20" MT installed right now but even with this power the stock clutch couldn't hold better than 1.8's. Already have the drive shaft as well, but thanks for the offer.
https://ls1tech.com/forums/dynamomet...ed-engine.html
Heres a great write-up by Tony himself (I know some of you are not a fan), as to why a better flowing set of heads really helps out overall power in a boosted application. It’s worth a read. He may have posted this on CF as well, and hopefully I’m not double posting. Forgive me if I’m out of line guys.
Like Unreal wrote, it's not a very ideal parts list, where you will likely run into the octane limit or power limit on the SBE. I would be worried about valve control with this topend AND boost. Say no to the Yella Terra Rockers, keep the stock LS7 rockers in it.
I appreciate the feedback guys. It's interesting on the positive comments and results around Tony's builds and around the great results from ECS supercharger setups but once you put them together people don't seem to like it. I think the ECS 1500 will be less stressed, producing lower boost, lower IAT's and produce more power with less boost, I went with an aggressive pulley combo to make boost come on fast bit limit boost up top with the restrictor. My thoughts are this will be a fun street car that is maxing out the stock bottom end. I guess we'll see after the tune and some track time, but I'm happy to be doing something different.
The nice part about boost is u don't have to buy all those fancy parts unless you're going big power with a built shortblock. Sometimes I wish I would have simply thrown a blower on my car with a mild boost cam. Would have been a lot easier! Although we have to fix heads so we're kind of forced to not keep things simple.
Most of the issue is the YT's.
If you only wanted to max the SBE, you could of fixed the heads, did a cam, and then slapped on a blower. 750 rwhp is usually the known limit of the SBE.
