Z51 front brake brackets
Old 07-22-2018, 04:55 PM
05 Wreck
05 Wreck's Avatar
Default Z51 front brake brackets
I have a set of front brackets. Is there any way to tell if they are Z51. I know they are taller than base, but I have no point of reference. Thanx.
Old 07-22-2018, 05:52 PM
cam1969
cam1969's Avatar
Do you have the rest of the car? If the rotors are 12.8", then they are z51 size.
Old 07-22-2018, 07:31 PM
05 Wreck
05 Wreck's Avatar
I know rotor size difference, I know piston size difference on rear calipers, etc. All I have is a pair of front brackets with nothing to compare them to.
Old 07-22-2018, 09:51 PM
irok
irok's Avatar
the heavy duty rotors would be 13.4" and not what you stated
Old 07-22-2018, 09:59 PM
irok
irok's Avatar
from the center outside edge of caliper to outside edge of abutment bracket will be 3 1/2"s
Old 07-23-2018, 12:41 AM
HOXXOH
HOXXOH's Avatar
Received 2,058 Likes on 1,503 Posts
C6 of Year Finalist (performance mods) 2019
Your term "taller" also has no point of reference. The brackets on the J55 brakes, which were part of the Z51 option and other base car options, are .3" larger on the front and .5" larger on the rear than the base (JL9) brake brackets, measured from the centerline of a mounting hole to a similar maximum point on the outer casting surface that's on a radial line to the hub center as compared to a JL9 bracket.
To Z51 front brake brackets
Quick Reply: Z51 front brake brackets
