What time is it? It's Howdy Doody Time!
I'm Batman..
Pro Mechanic
What time is it? It's Howdy Doody Time! (Big Build Thread)
Warning, this thread contains engine nudity and may contain graphic images for younger viewers. Viewer discrention is advised.
Figured I’d drop off a few graphic photos for you all
Received 5,216 Likes
Looking at this, apart from the obvious things of interest, I must say that you are a better man than I... to be installing the engine with the entirety of your car totally unprotected.
Art17 (01-10-2019)
What am I looking at, other than the anxiety from having the entire motor pulled and worrying not everything goes back exactly the same. I always wondered, how do you know where to route all the piping/electrical cables after you pull the motor? Service manual?
Art17 (01-10-2019)
I'm Batman..
Pro Mechanic
Aye.... easy there killer.. I said engine nudity. Theres plenty above to go around bud.. like that last pic where the “Block on Blocks bares it all..” LOL
rsvette12 (07-24-2018)
I have since car covered the car, no worries lol.
The key to making sure everything goes back the same way is being meticulous and documenting every bolt along the way. Then its easy..
I'm Batman..
Pro Mechanic
I needed to tap the pan for the YSI oil return line. So I took the pan off. When it was off I found two piston oil squirter nozzles broken off and sitting in the pan. The VR pistons apparently require the nozzles be “massaged” but there is no mention of it anywhere and when I called VR they said they never have to move them at all. Since i’m in here, I figure I will do rods and lower the compression so I can turn up the boost..
As for squirters i did bring this up in your previous POST >>> https://www.corvetteforum.com/forums...post1595966778
Didnt know they would break. Maybe add it to your HOWTO.. i just used a 17mm open wrench to give them a little bit of love
Bad ***. I love a good DIY thread. Good luck!
I'm Batman..
Pro Mechanic
Which pistons and rods are you doing now ? or is it just rods... more boost is always fun I wanna take mine out and do new cam/rods/pistons.
Now I am stepping up to a Stage 3 VR cam, with stock crank, Callies Ultra I beam rods, and Wiseco 10.5:1 pistons (dropping the CR from the current 11.7:1 VR drop in pistons). I am planning to sell the VR dropin pistons and rods (possibly the current crank as well) if anyone is interested. Already have the new cam here as well as a new set of Comp Cams 850 lifters. Wil be ordering some gaskets and such today. Will be doing cam bearings this time around as well.
Thanks!
Don’t jump to conclusions, I’m pretty sure it makes for a better pic without the covers or plastic wrap. Once the wrenching is done and the engine is out who needs covers I will also add that not everyone constantly fumbles tools or parts
I'm Batman..
Pro Mechanic
I am always a professional! Don’t need no stinkin plastic wrap!
I am well beyond meticulous and organized and don’t damage things when I work on them.
You know it brother!
Cruise-In IV Veteran
Do the LT Motors have the same rocker arm setup as the LS series motors? An if so are you going to be doing a trunnion upgrade or is it already done and if so which route did you go Bronze style bushings or needle bushings?
