Engine Oil leak
Engine Oil leak
I see drops of engine oil dripping around the oil pan underneath the car. I'm sure there is a systematic way to diagnose this leak. Any recommendations? I've read that it's common for the oil sensor unit to leak. I guess I could check there first but is there an easy way to see if oil is coming out of there without having to take stuff apart? The oil pressure gauge seems to be acting normal, though. I'm really praying this is an easy fix.
Pictures are really helpful. It could be any number of things. The oil pressure sensor is a good place to start. Also make sure your PCV system is in good shape. The best thing to do is clean everything really good and then start looking. Good Luck.
Moderator, Tech Contributor
Received 2,119 Likes
The systematic way to diagnose this is...clean up any remnants of the leak with Brakekleen and LOOK !!...can’t be any simpler !!!!!
rwobs777 is correct. Get the front of the car up a little, jack stands or ramps work fine, and spray everything you can reach under the engine with a degreaser. I've had good luck with biodegradable cleaners that you spay on, let set and then rinse with a hose. Do the same treatment under the hood being careful around electronic parts. Once everything is clean you'll be in a much better position to tell where the leak is coming from. You'll have to check periodically to find the leak if it's small.
You just have to look. A mirror and a flashlight or you might get your cell phone in close enough to take a picture. The small cheap borescopes for your cell phone also work well.
I think I found the area where the leak is dripping down from. Anything conclusive from this picture? This is on the passanger side. I'll take all the help I could get!
Please ignore the oily mess!
I tried getting my cell phone behind the manifold but it's too big. I'll try to find a small mirror on a stick and look back there.
