1986 head replacement
Hi All, want to replace my old early model L98 Ali heads.
This is what i have come up with.AFR Eliminatar
195cc/ chamber size 65cc or 75cc??
Angle plug.
the car is for street and we have installed a procharger D1. It goes good but not worth reco the old heads.
Angle plug.
The choice is yours, depends what you will do for pistons. You want to keep compression around 9.5 to one so target a head and piston that do that. 9.5 should work well with the blower.
Received 1,400 Likes
Chamber choice will depend on the CR you wanna run, I'd keep it lower and pick the piston and chamber to make it happen for the boost you wanna run..
