Dewitts special c6 group purchase?
Nice !!!!
I already have 1139105B but I might consider getting a fan. I won't have any cooling issues being N/A and E85 but am considering it to lower the load on the alternator with a 10% UD pulley. Is there a fan that would at least match stock cooling with the lowest draw possible?
Former Vendor
For anyone ordering the Dewitt's with the built in engine oil cooler I have the Katech block adapter and lines that run from the engine to the radiator I can sell you. PM me if interested.
Former Vendor
Former Vendor
There should be a "notes" field where you can make any comments. If not, just send an email to jcdingman@dewitts.com
Thanks
Still fighting issues here Tom Dewitt, newly installed 4139105A (TOC/FAN) 1 gallon antifreeze and two gallons + of distilled water.
Went on trip into hot weather, sitting in a traffic jam and temps went up to 236. Fans were both running fast. Going to put 36 OZ of water wetter in and see how that helps.
Is there a higher CFM fan than the one I got Tom?
AC did not shut off but this seems very high for a 94 95 degree day to me.
Because at low speeds it is all about the fans, not the radiator. Stock radiator is more than enough for moving for most cars, it is about getting good enough fans. You need to get the prospeed fan setup, and be done.
