FS: Vengeance Racing Used and New Parts via EBAY
Jason. (09-04-2018)
Former Vendor
Is there anything wrong with the LS7 IW damper? The description says sold as is. So any other details would be great. Thank you
Originally Posted by Vengeance
Racing;1597678282
Racing;1597678282
Please click the links below for more information... You can make offers through the EBay listings
C7 Corvette 8L90E Transmission With Circle D Converter
LT1 (Gen 5) High Pressure Fuel Pump 12669519
C7 Corvette Stingray Brake Rotors
LT4 Corvette Supercharger Lid
C7 Corvette Z06 or Z51 Rear Spoiler - Blade - Black
C7 Corvette Factory Torque Converter
C7 Z06 Corvette Factory Balancer - LT4 - 12662047
C7 Procharger Race Intercooler
C7 Z06 18% Overdrive Pulley
LT1 Style (Gen 5) Throttle Body Housing - Polished
LS3 Intake Manifold, Seals, Bolts, Rails, Injectors
LS2 Intake Manifold - 12589181
LS2 Throttle Body (Silver Blade) - Ported - 12570790
ARE LS7 Style Dry Sump Pan With 2-Stage Scavenge Pump
LS7 (Gen 4) Front Engine Cover - 12579941
LS7 Innovators West 6-Rib Harmonic Balancer - Standard Diameter
LS3 (GM) Fuel Rail With Injector Clips
C6 Or C5 Corvette Z06 front Sway Bar - 30mm - 10419094
C6 Z06 Torque Tube - (2005-2006)
C6 Corvette Shock Absorbers (used)
C6 Wide Body Bogart Racing Wheels (15 x 10 Bead Locks)
C6 Or C5 Front Leaf Spring - 15233397 - FE1 (Soft Ride)
C6 Rear Leaf Spring - 15233388 - FE1 (Soft Ride)
C6 Differential - 2.56 Gear Without Cooling System - 24235244
C6 Passenger Side Air Bag
C6 XM Radio Antenna
LS7 Intake Manifold With Carbon Fiber HydroDip
GM LS3 Clutch (used)
LS7 Balancer
C5 Z06 Differential 3.42 Ratio - 12572683
C5 Corvette Factory Rear Window (Fixed Roof)
C5 Corvette Rear Spindles/Hubs Modified For Strange Race Brakes
C5 Corvette ABS Bracket
C5 Corvette Front Wheel Houses (wheel wells)
C5 Corvette Rear Upper Control Arms
C5 Corvette Rear Lower Control Arms
C5 Corvette Rear Wheel Hubs - 30-Spline
C5 Or C6 Corvette Z06 front Sway Bar - 30mm - 10419094
C5 Corvette Rear Subframe Cross Member - 10266823
C5 Corvette Front K-Member Subframe - 10319530
C5 Corvette Front K-Member - 10312076
C5 Rear Brake Calipers for 15-Inch Conversion
C5 Radiator Fans
C5 Custom Ram Air System (for dual 4150 throttle bodies)
C5 Z06 Driver's Seat With Bracket - Mod Red
C5 Corvette Alternator (painted Black) - 10316182
C5 Corvette HVAC Box (Under Dash)
C5 Corvette Dewitts Pro Series Radiator for 2001-2004 C5 Corvettes (1139101A)
C5 Wiper Control Stalk Switch - 260047377
C5 Turn Signal Stalk Switch - 26075870
C5 Leather Wrapped Steering Wheel - Black - 10424050
C5 Passenger Side Air Bag - 2002 Model
C5 A&A Corvette Secondary Belt Drive (single Bracket And Belt Only)
C5 Driver's Side Quarter Panel - Arctic White
C5 Fuel Door - Arctic White
C5 Radiator (manual Trans)
LSx Solid Roller Camshaft (260/272 .754/.751 115LSA) - Some Damage
LSx Solid Roller Camshaft (256/268 .748/.748 115LSA) - Some Damage
Toyo Proxes R888R 325/30ZR20 Tires (PAIR)
Pirelli P-Zero Tires - Trofeo R - 305/30ZR20 (PAIR)
LT1 Camaro (Gen 5) Valve Covers
LS (Gen 3 or Gen 4) Valve Covers
Strange Engineering Brake Rotor - B2794L
Morel LS Tie Bar Lifters - 5850 - Short Travel
Pro Torque Converter TH400 - Used in our C6 Race Car
DCM Axial Electric Puller Fan - 860026
Bill Miller Forged Aluminum Connecting Rods
Magnuson 10-Rib 3.200 Diameter Supercharger Pulley
Magnuson 96mm Supercharger Pulley (57-03-06-096-BL)
A&A Corvette 8-Rib, Cross Cut Supercharger Pulley - 3.00 Diameter
A&A Corvette 8-Rib Supercharger Pulley - 4.0 Diameter
ISKY 9968-RAD Tool Room Valve Springs
Napa 1-4866 Power Steering Cooler
Holley 860015 102mm Sniper Throttle Body Spacer
Mass Airflow Sensor For LS Engines - 5-Wire
Cometic LS7 Head Gasket - C5889-070
Wiseco Wrist Pins For LS Engines
Mantic 9000 Series Flywheel - F9001H
Gates K080889HD Belt - Green Stripe
Gates K080855 Belt - 8PK2173
CM Pushrods 7.225" 5/16" .080
CM Pushrods 7.850” 5/16” .080
CM Pushrods 8.050" 3/8" .080
Cometic MLS Head Gasket (Left Side)
Cometic LSX Head Gasket (single) 4.140" Bore, .060" Thickness, 6-Bolt
Durabond CH-23 Cam Bearings
C6 XM Radio Antenna
LS7 Balancer
C5 Radiator Fans
Former Vendor
