Tough to make a decision......
I'm really struggling to decide which way I want to go to modify my car. Part of me wants to build the motor first in case I get the bug and want to go over 650 WHP. The other part of me wants to just put bolt ons on my stok motor and play with whatever gains that gives me. I have a quote I like from futural that basically gives me a d1x procharger, procharger intake manifold, and headers. Not sure how much HP this will be, but I think it should be in the safe range for the bottom end of the LT1. I also have a quote to build a 416 bottom end that will be good for 1400 WHP with a cam for about the same money. I don't think I'd ever want that much, 800 is probably my max, but itd be nice to know its strong.
Should I just go with a safe charger build, and come back and build the motor later if I feel like I want more power. I pretty much know if I build the motor I'm gonna want more power cause its gonna be less HP than I really want.
This is whats called first world problems. lol
Cruise-In IV Veteran
If you are already feeling the HP bug, trust me, you will get bored of 600 wheel also. Then want more later. Just do the motor that sets you up for either a nice reliable all motor build that has a LOT of room to grow. Course you would need to pick the compression and cam for either ALL MOTOR or FORCED INDUCTION. So doing a 416 with lower compression leaves lots of power on the table which could be filled later. Still all comes down to future goals even doing an all motor build now. Keep this in mind, getting BIG numbers requires modified fuel system (low + high + cam + possibly 30% larger DI injectors OR low + port injection system) both of which are not cheap. Really think hard about what you want down the line. If you truly are OK with 600 wheel then just stick with a procharger build. Otherwise it will get $$ fast...
samwint77 (08-09-2018)
Received 1,762 Likes
ttt
I am doing a drop in CP forged ci pistons & rods with stock crank. Also doing a LT4 inj & pump & a BTR stage II cam & Circle D converter also a set of ported & worked heads. I have on the car now with stock short block is LT header x pipe A/A TI head unit with a 3.4 pulley with meth.
I just got my rods & pistons in today will be doing this soon now...I have done the 1400 rwhp stuff in the c5 will hold this set up on the c7 to what the above parts will hold at around 800 rwhp & have some fun...OP got all my parts from a great vendor in here let me know if you want to go this way.... Robert
samwint77 (08-21-2018)
So you might as well buy the Z06 they are the better car and they resale is better. JMHO!
I did my bottom work beforehand as well. It's the set it and forget it mentality. My limiting factor now is clutch,tube,meth and shafts so im keeping it below 800 for the time being. I went with a V7 YSi but slowed it down.
I know around 800 should be a good safe # plus to pull almost anything around here in my town. As soon as I get my Circle D converter in going to get this ball a rolling on this set up & going to call it done. Robert
I am doing a small build stock ci with forged lower parts, with ONLY a A/A TI head unit with meth & LT4 INJ & PUMP & BTR stage II small came only. Believe me you will love the car more with something that you can get into & go anyplace you want to go here. Robert
with you Billy for a excellent street driving car this is one of the best ways to go with this car. It really is to nice of a car to per say making a streetable race car out of it with 1,k plus rwhp.. Get in in & go anyplace you want with what you are saying here.... Robert
Billy@MTI (08-29-2018)
