Added headlight “eyelids” on the cheap.
Never was sure whether I really liked the eyelids, especially when the commercial vendor priceswere around $100.
So after adding a roof stripe to extend my stinger stripe,
here: https://www.corvetteforum.com/forums/c7-general-discussion/4161666-added-roof-stripe-to-extend-stinger.html
I decided to try my hand on the eyelids.The cost was about $14.00 for the vinyl, so figured if I didn’t like it or got tired of it there was no large loss.I’m pleased with the outcome and will keep them on for a while.
The following 5 users liked this post by agapsdiver:
Art17 (11-05-2018),
beaversstonehaven (08-18-2018),
Bob Beroza (08-09-2018),
Gravitas (09-22-2023),
Rebel Yell (08-09-2018)
Well done. Looks great . Your C7 is beautiful
The following 2 users liked this post by marc4427:
agapsdiver (08-09-2018),
Art17 (11-05-2018)
The following 2 users liked this post by DWS44:
Art17 (11-05-2018)
Avanti (09-18-2023)
I think it looks better on a Ferrari with no panel gap....like this weak photoshop attempt....
But I can appreciate your craftsmanship. Well done.
Nice job looks good.
I hope the match is OK down the road. Silver is a tough color to match, especially with the angle of the metallic flakes not matching the factory angle.
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Nicely executed.....
Pro Mechanic
Received 3,938 Likes
Great job, and both of your mods. were tastefully done!
down the road... the gap won't be noticed. I have helped two other C7 owners I've met at car meets wanting the
steps and equipment needed to make their own.
The following 3 users liked this post by agapsdiver:
I like!
Actually, I tried to do it myself but I was scared to take an exact o-knife and tried to cut out the shape based on a template. It ok from 10 feet way. I would like to try again. Other than skill and practice, which I have no desire to do on the car, how do you avoid accidentally cutting into the car when you trim the material?
He's using knifeless cutting tape... no razor blades required. Example below, many different sources.
https://vvividshop.com/products/knif...tting-tape-10m
looks good but I've never been a big fan of the eyelid look. like the color matching on your z06 grill more. Did you do vinyl there as well or paint?
at top, green line is the knifeless tape,
and used a razor knife carefully along the seam
between the headlight and the body panel ...plenty of room to cut.
The brake ducts were painted "aluminum" Plasti-dip. I wasn't trying to
match the body color, wanted a more metal look for the ducts.
And by using Plasti-dip if I didn't like it I could easly remove.
That was almost 4 years ago and still no problem with the dip.
Pic below taken after knifeless tape cut has been made.
The following 2 users liked this post by agapsdiver:
Clifftrail (08-18-2018),
Flame Red (08-18-2018)
