Econo boost - lil thumper for sale
hi folks, my other vette a nice LPE ZR-1 punched out a Head gasket which means pull and port!!! will run some serious coin so lil thumper is for sale
4.8 iron block bored .020 over with wisco 9.5 forged pistons, gen 4 rods with sps bolts, stock std 3.22 crank, new bearings rings, fresh from machine shop
799 heads (same castings as z06 heads)
garrett t60 to4 turbos with tial wastegages, air to air intercooler, 80 lb injectors, ls1 intake custom intake tube with dual blow off valves. LPE tuned ecm and wiring, 80 lb injectors,
custom modified truck oil pan with drain backs.
all high quality stuff ready to assemble and go. Short block is fresh and ready, all parts included except gaskets (use ls9).
this setup will make over 900 hp, turbos will go even more if you dare
this little puppy will take some abuse and is ready to rock and fresh from the machine shop
previously ran 9.20s at 151 mph in a c2 64 vette. just freshened up. over 9000 worth of parts in this build not including machine work (1250)
freshened up with stronger rods and ready to go
I need 5500 for the complete engine or 3500 for the engine minus the turbo system (long block + intake injectors)
I also have the turbo system still that won't fit modern c4 and up,but it will work with c2/3 corvettes if interested. on ebay now for complete engine
offering the long block only here in case that falls through
previously ran 9.20s at 151 mph in a c2 64 vette making around 900 hp
I need 3500 for the long block
CorvetteBrent (09-21-2018)
