C8.R packs in flat-plane V8
With the leaked audio clip C8.R sound in which the engine sounds smooth and deep. It can most-probably be result of Flat-Plane crank. First I thought it was due to implementation of Turbos, but turbos cannot make Corvette Cross-plane V8 sound like that nor can exhaust system. Yes I realize that it is not official but the audio clip of the C8.R sound make it sound more like European V8 and only deduction for it can be inclusion of flat-plane crank instead of cross-plane.
Audio Clip of C8.R:
https://sportscar365.com/industry/au...-turbo-engine/
Finally Chevrolet decides to drop in Flat-plane V8 in Corvette. Never thought they will drop it in so soon. This video makes my point even strong.
Sound of C8:
This video makes my point of it being FPC V8 even strong.
Latest Reveal Possibly a Hint:
This video at 6:04Min and 6:34Min makes my feeling about it being FPC even stronger
C8-R Sound on Track:
Sounds lot different than traditional American V8.
Corvette C8 Lineup to have Flat-Plane-Crank and Hybrid System up the Line
https://www.caranddriver.com/news/a2...hybrid-engine/
Corvette C8-R Teaser:
Now the only thing is for the Chevrolet to officially announce the specs. I am 100% sure it is FPC V8 and not V6 or Turbo V8 with some special exhaust.
Audio Clip of C8.R:
Sound of C8:
The following 2 users liked this post by King Dranzer:
Puttnutt24 (08-13-2018),
rsvette12 (09-20-2018)
vettesweetnos (08-30-2019)
Sounds like a higher displacement 488, but engine design an header arrangement could play games on that. Would be interested if they go a DCT route or not for a street car based on the blip shifts in the video.
The following 2 users liked this post by tomlink:
B747VET (08-30-2019),
blackcorvette06 (10-08-2019)
But from what I have been reading recently about oil burning and engine grenading, I'm not so sure they have mastered it yet...
It wouldn't be a bad idea for GM to go this route on a performance only engine, but I somehow don't believe it. Unless GM is going to share this FPC engine, in basic form, with another platform(s), it brings the unit price up with the low production Vette being the only customer.
Michael A (10-07-2019)
Yep
I have one, and I can attest to mounting concerns of many who either have one or who are thinking about buying one. My first....and last Ford. Looking at '19 Z06's now. Another thing about these high revving overhead cam motors is that they don't have the low RPM torque Corvette owners are used to. In the Shelby, really need get well into the 3 grand RPM range before "wake up time." Glorious exhaust notes, fun at the higher RPMs, but something small block Corvette owners are not used to, and frankly, much more suited to track than street. Also, IMHO 5.2 liters just too big for the FPC, massive vibrations issues that Ford had to deal with besides the other problems...
The following 5 users liked this post by NineVettes:
638HP (06-20-2020),
kenownr (09-21-2018),
Michael A (06-20-2020),
Tripjammer (10-08-2019)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
JockItch (08-12-2018)
Supporting Vendor
Received 2,316 Likes
The 2019 Silverado 4cyl will make 349 ft/lbs from 1500rpm to 4k rpm...torque production won't be a problem, when combined with an engine redesign. I built huge power 4 cylinder engines when I owned 2 shops in the late 2000's...even with large volume, heavily modified systems, using properly sized Garrett ball bearing chra's I could produce torque onset well under 3k rpm. I highly suspect they will use cam phasing in the new dohc heads, which will create cam advance at low rpm and overlap variations to increase exhaust velocity. I'd also suspect some type of divided housing turbo. Torque definitely will not be a problem.
As for those Ford GT's....easily the worst sounding cars in the entire weathertech/wec...lol.
No way that is a V6. Sound from that Ford GT vid posted is VERY different as well. I'm not in agreement with the FPC belief either, but the sound of the Corvette based car is incredible. I almost hope GM puts an option on the sheet that allows for such a scream at the higher RPM levels........
This LS7 Passat sounds like nothing else with just custom headers. You would never know its an LS with the hood closed.
https://youtu.be/Qq8zEJHWT7g
Take time to listen to this. Just the new ME exhaust configuration can change a lot of things.
