700R4 question
Received 5,516 Likes
700R4 question
I have a C1, but it has a 700R4 behind a 370HP 350 crate engine.
This will sound like a weird question, but should I be able to roll the car around when the engine is off and the tranny is in Drive or Reverse? It rolls just like it is in neutral. In Park the pall engages and it doesn’t move. I’m having a very strange starting problem and I had to push the car back into the garage which is how I discovered it.
That sounds normal to me. If the car stalls will driving, it will coast untill it runs out of momentum. It's not like a manual transmission where it's in gear and turns the engine with the wheels. You theoretically should be able to push it around while it's in drive but I have never tried.
I could be wrong so someone please correct me if I am.
Factoid (08-10-2018)
But if you are right, it will be a huge relief!
Thank you! I was starting to convince myself that the PO had the TV cable screwed up and trashed the tranny.
I push mine around frequently when working on it. All I hear on my 1988 C4 is the brakes dragging a bit while pushing it. The only squeaks I get are from the suspension when pushing or releasing pressure on the body.
That is a Beautiful Corvette you have there, with the additional horsepower it must be even more fun!
Best regards,
Chris
Best regards,
Chris
Normal. Pushing the car backwards, you may hear a "screech" or constant "squeak". This too is normal, in that rolling car backwards causes the lo-roller clutch to slip, and its elements make noise as they slip. There is also more resistance pushing it backwards. Also normal.
