Replace or repair dash pad?
I need some suggestions on how to replace the dash pad or getting it repaired? It was scratched but not deep to a cut. I have seen videos online of dash repair and it looks promising but I'm scared how it will hold up to the heat and the visual look of it after its repaired. I am very mechanically inclined and would rip the whole dash out just to replace this eye sore.. lol
Received 19,289 Likes
'20-'21-'22-'23-'24
I had a vendor called Dr. Vinyl repair the dash on an ‘84 Vette I had and it came out looking as though nothing had ever happened. It also lasted from the time I bought the car until I traded it in (around 5 years) and still looked great.
Check with your dealer and see who they use to repair interior issues and see what they can do. Worth a shot before going to the expense of buying parts and tearing the dash apart.
I would first take it to a good car upholstery repair shop and see what they say about repairing it and ask to see some of their work.
To replace that dash piece would be a nightmare. Here are instructions just to replace the passenger side trim pad.
https://www.corvetteforum.com/forums...nger-dash.html
You still need to keep going to replace the dash after that.
Received 1,762 Likes
The dash is one piece. So to replace would mean everything above your knees comes out. A big job.
so, another guy used the service manual and did that to replace the dash pad with the air vents and took 8 hours. Another guy said he took apart the glove box and did the same job in two; without removing the center console. It appears it is a triangular piece only. Can I go into it from the glove box area? Can a leather guy just replace the ripped area? Can I replace the air bag from underneath? Do you have any pictures of the underside of the panel?
Any help would be appreciated.
Thanks, Jack
Thanks, Jack
You got nothing to lose having a pro look at it.I wouldn't stop at the first ..No i can't do that.Hopefully they can
Your car appears to be a 3LT, meaning that your dash is covered in leather, not vinyl. I agree with what others have said here: Seek out a professional opinion. Good luck!
But in any case, look for advice from pros or from someone who actually has done the switch on his own.
