C8 General Discussion The place to discuss the next generation of Corvette.
New ME Patents Approved for Active Side Skirts, Spoiler & Downforce Generating Ducts
Old 08-13-2018, 04:47 PM
jagamajajaran
Support Corvetteforum!
jagamajajaran's Avatar
Received 9,512 Likes on 2,317 Posts
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Default New ME Patents Approved for Active Side Skirts, Spoiler & Downforce Generating Ducts
http://www.corvetteblogger.com/2018/...erating-ducts/
The following is an excerpt from the blog post linked above:
Active Side Skirts:
The patent publication explains that vehicle side skirts are an aerodynamic device typically fitted to a vehicle body side between the front and rear wheels. The purpose is to help streamline ambient airflow around the rear wheels to reduce drag. According to the summary in the patent, the larger the area of the side skirts, the lower aerodynamic drag on the vehicle.
The Active Side Skirt system utilizes sensors to detect the rotating speed of the wheel as well as the speed of the vehicle relative to the road surface, and a controller is programmed to send commands to actuators that can extend and retract the side skirts "toward and away from the road surface".
Active Spoilers
Like the side skirts, spoilers are used to "spoil" unfavorable air movement across the body of a vehicle in motion, usually described as turbulence or drag. Adding a spoiler at the rear of the vehicle helps to delay airflow separation from the body. As we have learned recently from the two different styles of the spoilers on the 2019 Corvette ZR1, a spoiler mounted as a certain height and angle can either help to reduce lift and create downforce like the ZR1's high wing, or it can be used to streamline the airflow to reduce drag as is the function of the ZR1's low wing.
Of course, nobody wants to carry around two different spoilers. So the Active Spoiler system detailed in the Patent publication solves that problem.
Stanchions are used to support the spoiler body relative to the car. Connected to a gear and motor system, they can be configured to vary the height of the spoiler. A second process is configured to selectively pivot the body of the spoiler to change the angle and thereby adjust the aerodynamic downforce generated by the spoiler.
Like the active side skirts, the active spoiler can include sensors that communicate a variety of information for controlling the active spoiler. Sensors look at the rotating speed of the rear wheels as well as detecting the velocity of ambient airflow relative to the vehicle. Other sensors look at the steering wheel angle as well as detecting the yaw rate. All these sensors feed information to the controller which then adjusts the height and angle of the spoiler.
This next patent is pretty straightforward for what is described as downforce generating ducts. We all know that ducts are used on the Corvette to move air from one part of the car to another. The C7 Corvettes featured ducts on the rear quarter panels that are used for cooling the transmission and differential fluids. On a mid-engine platform, cooling is even more important as you need forward-facing ducts to capture the air and then route to the various areas that need additional cooling.
In this patent publication, GM describes the ducts as a fully-enclosed structure, and it contains a first or entry port positioned to receive the ambient airflow and a second or exit port to exhaust the airflow from the duct. The first and second ports together with the fully-enclosed structured are configured to generate an aerodynamic downforce on the vehicle body when it's in motion.
GM also notes that the ducts can be found both top and bottom of the car and that they can include a venturi to accelerate the portion of the oncoming ambient airflow.
Old 08-13-2018, 05:00 PM
RapidC84B
RapidC84B's Avatar
Received 13,145 Likes on 5,983 Posts
Very neat... but more **** to break. Or you change the wheels and all the calibrations go to ****.
CitznFish (08-22-2018)
Old 08-13-2018, 06:35 PM
Quinten33
Quinten33's Avatar
I like the downforce duct idea. Integrated aerodynamics make for cleaner designs.
I hope that they make the entire underside flat, just the way McLaren does so on the 570s.
Old 08-13-2018, 08:10 PM
eyedeekay
eyedeekay's Avatar
I wonder if the active aero is only going to be implemented in higher performance model only, I just don't see an active aero mid engine car going for under a 100k. For reference, the 2018 911 Turbo (which we have seen spy shots of the mid engine car driving alongside the turbo's more expensive brother 911 Turbo S, msrp 191k) has active aero less extensive than whats proposed in the patent and the msrp is 161k. Similarly, the mclaren 570s which has no active aero is 190k msrp.
Old 08-14-2018, 10:44 AM
WhiteDiamond
WhiteDiamond's Avatar
St. Jude Donor '15
Simple evolution of power and performance.
Old 08-21-2018, 11:09 AM
C5Driver
C5Driver's Avatar
This tells me one thing the M/E is no entry level or base type of Corvette if its going to incorporate such complex systems.
Old 08-21-2018, 11:12 AM
C5Driver
C5Driver's Avatar
If you need mid engine why not just buy the 911? Its at least proven.
Old 08-21-2018, 05:18 PM
bebezote
bebezote's Avatar
this is very exciting...was wondering if active aero was coming... great find!
Old 08-21-2018, 06:19 PM
tomlink
tomlink's Avatar
911s are rear-engined.
ArmchairArchitect (08-22-2018)
Old 08-21-2018, 06:27 PM
sstonebreaker
sstonebreaker's Avatar
They're planning on leaving the Ford GT in the dust.
Corvette_Nut (08-22-2018)
Old 08-21-2018, 06:30 PM
MitchAlsup
MitchAlsup's Avatar
Received 1,590 Likes on 783 Posts
Well, first, the 911 is not mid engined.
Old 08-21-2018, 07:27 PM
jimmyb
jimmyb's Avatar
Received 4,248 Likes on 2,023 Posts
Hey now, don't start junking up a thread with FACTS.
Old 08-22-2018, 02:04 PM
NemesisC5
NemesisC5's Avatar
Adding additional link to your thread - patents appeared in database 8-21-18
Two Stage Turbocharger and Front Bumper Cover Design Could Be Headed for Mid-Engine C8 Corvette
Old 08-22-2018, 02:13 PM
RapidC84B
RapidC84B's Avatar
Those fascias look nothing like the ME leaked paint shop image.
Old 08-22-2018, 02:38 PM
Corvette_Nut
Corvette_Nut's Avatar
Location: Hailing From The Mean Streets Of Irvine, California
Received 4,153 Likes on 1,314 Posts
It seems like Team Corvette is Answering The Call And Taking No Prisoners! Exciting Times For Us Corvette Fans! Exciting Times....
Save The Wave,
Corvette_Nut
Old 08-22-2018, 02:41 PM
NemesisC5
NemesisC5's Avatar
I agree, don't understand how they see close similarity.
Catching my attention is GM's focus on advancement of turbo systems.
Old 08-22-2018, 06:12 PM
Kodiak Bear
Kodiak Bear's Avatar
Yes but the 911 RSR is mid rear. The IMSA racing rules allow a certain amount of relocation of the engine. Within those allowances, Porsche was able to produce a mid rear racing car. Their official reason was to improve the aerodynamics of the car.
To New ME Patents Approved for Active Side Skirts, Spoiler & Downforce Generating Ducts
Old 08-22-2018, 06:17 PM
Kodiak Bear
Shades of the Chaparrel 2J sucker car. When banned from Can Am racing, Jim Hall offered to build a car with movable aerodynamics that produced the sucker effect without having a sucker driven fan. The officilas said no. Beginning of the end of Can Am, IMO
Anyway, the actual aero devices on this car must be bringing a smile to Hall.
Old 08-22-2018, 07:00 PM
JimNeedsC7
JimNeedsC7's Avatar
Well, that is because that is a C7 Chevy used for the patent application and not a C8. If that is a mid engine car then the steering wheel is facing toward the rear and that would certainly be an exciting new development.
Those active aero features are interesting and would most likely only be on higher level C8s and not the rumored push rod entry level model.
Old 08-22-2018, 07:45 PM
copjsd
copjsd's Avatar
Hello, Tool Hoarder,
I hold a couple patents, and from my experience the U.S. Patent applications use diagrams only to convey the embodiment of the patent seeking technology. In this particular case, my assumption is that the C7 diagram was used for convenience, as well as to not show GM's hand on what vehicle(s) this future technology may ultimately be employed.
Best,
Joe
JimNeedsC7 (08-22-2018)
Quick Reply: New ME Patents Approved for Active Side Skirts, Spoiler & Downforce Generating Ducts
