Vented cubby lid
Vented cubby lid
Does anyone know if there is a source for a vented rear storage cubby lid? I'm installing a small JL 1 channel amplifier in the cubby and want to ensure adequate ventilation. I've seen some install photos of vented cubby lids, but can't find a source. If anyone ended up making their own any tips would be appreciated.
CrystalRedTed (08-14-2018)
If you vent the lid, you will have to vent the carpet, or it won't do any good. I would go to Home Depot and check out their wire mesh products. You could easily buy a piece of the heavier wire mesh, cut it to fit the hole, and just put in place of the door. Cut the carpet opening a little smaller, and you are done. Save the carpet piece to fix with back-side mending tape when you are ready to sell the car.
Never seen the vent cubby lid OP mentions.
Great DIY project.
Advise...
Measure twice cut once.
Remove the lid from the car, I would.
Hole saw.
Not sure if cutting though carpet glued to the top of the cubby will bring issues.
After the holes are cut, add some screen for style.
Great idea/ project good luck.
Great DIY project.
Advise...
Hole saw.
Two thoughts.
1) Dont put it there, that's nearly the hottest place in the car. Put it under the paste get foot well with the nose amp if anything. There is copious amounts of room as well as all the electrical hook ups you need there
2) if you do put it there, just trim the backside of the console instead of a hole in it. Just trim off a half inch from the back so it doesn't seal up as well (not that it seals well at all but whatever).
Great DIY project.
Advise...
Hole saw.
Great DIY project.
Advise...
Hole saw.
Good suggestion. I was thinking in terms of a square cutout, since that was the example I saw. However a couple of circular holes drilled out with a hole saw will be far more straigthforward!
Two thoughts.
For better or worse I already have the amp wired up in the cubby. It seems like every locations has its issues. When I was under the dash running the power for the amp it didn't look like there was a whole lot of room for an amp in the passenger footwell....maybe because I have the Bose system with an amp under there already? I'll check out your suggestion about trimming the back side of the lid.
I went a different route with the ventilation. I took the advice of buckmeister2 and just put in a mesh grill from Home Depot. It seems like it will do the job. This way I don't have to commit to mutilating the cubby door and can just reinstall it if I have to move the amplifier elsewhere. Picture of the grill bellow. I have the luggage cover so it won't be visible from outside. You'll notice the rubber mat - I'm just going to take that out of the car rather than cut it up. I'm not hauling manure so the trunk mat isn't super critical.
That is not the cubby I was thiking of! I was thinking the center console. For that, I'be tempted to just wedge it slightly open. But the grate does look nice. Guessing it's for a small sub?
The center console is where my dashcam battery and AT&T Mobley hot spot live.
