Automatic to Muncie 4 speed swap
I have been searching the forms for a thread that would try to help me with a swap in my 73 corvette with a automatic to a Muncie 4 speed. If someone know of a thread or link that would give me a step by step idea that would be amazing. I would imagine it has been done before by a number of people. I am looking to see what parts I would need and if it would be a simple bolt on (being they came factor with 4 speed) or if there is heavy modification needed to make it work. Any and all help is much appreciated thanks guys!
Check the posts over the last two weeks. There is a guy with a 73 BB looking to convert to an automatic. Sounds like a match made in heaven. I had looked at this conversion for a 69 and it was relatively simple.and I put a list of the things I remembered from my research on that post.
<73Vette> (08-16-2018)
Yeah, but Oregon to N. Dakota is a hike. https://www.corvetteforum.com/forums...th-an-automati
Go to Silver Sport Transmission and pull up the parts list they show that is included in their kit to do the swap from an auto to manual.
This should give you an idea of the parts needed to do a full swap.
They will sell you the parts you need without purchasing the full kit or if you don't purchase their transmission.
They also have a link to the installation manual to do the swap.
This should give you an idea what work you will need to do.
<73Vette> (08-17-2018)
here is a decent list, although not exhaustive...
z-bar bracket
weld bracket mount on frame if not already there
ball and stud for z-bar mount.
pedal assembly
pedal pads
pedal push rod
pedal push rod boot
pedal foot pads
flywheel ( resurfaced if not new ) ( re-balance if 454)
flywheel bolts (with loctite)
bell housing
clutch and pressure plate
pilot bearing
throwout bearing
clutch fork
clutch fork ball pivot.
transmission, rebuilt with new seals/synchros
shifter
shifter mount brackets
shifter linkage
shifter boot
speedometer driven gears
speedometer drive gears
ujoint
rear transmission yoke
gear oil
reverse lockout setup
depending on year, emisions hookups
driveshaft length changes?
transmission mounts interchangeable?
Backup light switch.
trans to bellhousing bolts.
bellhousing to engine block bolts
console lettering and numbering plate for 4-speed, misc console changes.
remove tranny coolant lines
exhaust hold up bracket
z-bar bracket
pedal assembly
pedal pads
pedal push rod
pedal push rod boot
pedal foot pads
bell housing
pilot bearing
throwout bearing
clutch fork
shifter
shifter linkage
shifter boot
ujoint
gear oil
<73Vette> (08-18-2018)
